Thread: 00 GT Fuel Gauge
Results 1 to 5 of 5
  1. #1 00 GT Fuel Gauge
    Dec 2008
    Pittsburgh
    I have a 2000 GP and my fuel gauge is not working. When i start the car, the gauge is in position where I would estimate the fuel level to be. As soon as the car has been moving for 10 minutes or so, it will move to full then work it's way down to empty, then back and forth. I have changed the fuel pump and the instrument cluster already.
    Any other ideas on what is going on with it??
    TIA
  2. #2 Re: 00 GT Fuel Gauge
    Apr 2008
    Chillin at the Beach , VA
    To me sounds like a bad sending unit or possibly a bad ground.
  3. #3 Re: 00 GT Fuel Gauge
    Dec 2008
    Pittsburgh
    After using the search function, I have found the sending units are common to go bad.
    Is the sending unit part of the complete fuel pump module?
    TIA
  4. #4 Re: 00 GT Fuel Gauge
    Apr 2008
    Here is some info that I found that should help you out.
    Fuel Level Sending Unit - Automotive Forums .com Car Chat
  5. #5 Re: 00 GT Fuel Gauge
    Jan 2009
    Lincoln
    I would probably say it is the fuel level sensor, I had the samething go out on my 01 GP, they are not too teribly bad to replace if you plan on doing it yourself. There is a access door through your trunk that you can take off and have access to you fuel pump module, just make sure that you have a half of tank or less or you might make a mess with gas in your trunk. If you take your GP to a repair shop make sure they do not charge you to drop the tank and a additional charge to drain your tank.
    Hope this helps!!
  1. Fuel Gauge
    By agent505 in forum General Tech Discussion
    Last Post: 05-06-2010, 11:07 AM
  2. 97 gtp fuel gauge problem???
    By iwinagn in forum General Tech Discussion
    Last Post: 07-28-2008, 01:32 PM
  3. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
  4. Fuel Gauge Problems
    By thermanlee in forum General Tech Discussion
    Last Post: 05-29-2008, 12:33 PM
  5. anyone have a Prosport fuel pressure gauge?
    By fst in forum PCM Tuning
    Last Post: 04-02-2008, 06:38 AM
