Thread: What do I need to change to put a 2006 motor in a 2004? N/A
Results 1 to 4 of 4
  1. #1 What do I need to change to put a 2006 motor in a 2004? N/A
    Oct 2011
    N.H.
    Non supercharged. I assume some sensors and maybe manifolds?
    Thanks for the help!
  2. #2 Re: What do I need to change to put a 2006 motor in a 2004? N/A
    If both motors are N/A like you say, its pretty much a 100% direct swap.
    There should be no changes in sensors from the 2 years.
    Some things could be replaced while the motor is waiting to go in though. Like check to see if the intake gaskets are metal and not plastic and make sure the rear main seal is not leaking.
  3. #3 Re: What do I need to change to put a 2006 motor in a 2004? N/A
    St. Louis
    I thought it was the rear cover that leaked, not so much the seal itself??
    I'd do valve cover gaskets/grommets too. New return line on the PS pump maybe as well.
  4. #4 Re: What do I need to change to put a 2006 motor in a 2004? N/A
    Oct 2011
    N.H.
    Thanks guys, I really appreciate the info!!
  1. 2004 gtp seat change.
    By slap in forum General Tech Discussion
    Last Post: 08-26-2012, 07:18 PM
  2. 2004 gtp seat change.
    By slap in forum Members Rides
  3. 2006 blower motor issue: TSB?
    By TexasGP in forum General Tech Discussion
    Last Post: 04-03-2011, 06:39 PM
  4. 2004-2006 special rear facia
    By gpgtstan in forum Shops and Community Heroes
    Last Post: 07-31-2010, 10:36 PM
  5. Engine Swap?? 2006 to 2004
    By gmangrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 09:13 AM
