Thread: Burnt Rubber from Vents?
Results 1 to 4 of 4
  1. #1 Burnt Rubber from Vents?
    SE Level Member KitRae's Avatar
    Jul 2012
    St. Catharines
    OK, I have a burnt rubber smell coming from the Vents. This happens when I am sitting idle at night to keep warm. It seems to only come from the Drivers Side Vents. Heater Controls are not working correctly either. I have Dual climate control and the drivers side control hits and misses when trying to get heat.
    Could someone figure out what this issue is or have any ideas of what could be causing this?
    2002 Grand Prix GT 3.8L Naturally Aspirated
    - NGK Iridium Performance Spark Plugs
    - NGK 51031 Performance Spark Plug Wires
    - EPR Cross Drilled Performance Brakes & Ceramic Pads
  2. #2 Re: Burnt Rubber from Vents?
    check your belt on the engine. air gets sucked in from the pass side cowl area into the car.
    the driver side problem is the blend door actuator. http://www.grandprixforums.net/showt...door+actuators
  3. #3 Re: Burnt Rubber from Vents?
    Jul 2012
    St. Catharines
    Ok. Will check that as getting the wheel bearing and fuel filter replaced on Mon.
    Sent from my GT-S5690M using Tapatalk 2
  4. #4 Re: Burnt Rubber from Vents?
    Jul 2012
    St. Catharines
    Well. Took it in and they checked everthing out. Nothing found out of ordinary. Had to replace the MAF and the wheel bearing. Now the smell has disqppeared. Must have been the bearing. Ah well. Leqst the car is working better now.
  1. Burnt My GTP
    By hammerline81 in forum The Rant Forum
    Last Post: 12-11-2013, 01:44 AM
  2. Burnt out bulbs?
    By nos4blood70 in forum General Tech Discussion
    Last Post: 12-30-2012, 12:00 AM
  3. Newbie and a burnt out DIC
    By Polly Anna in forum Introductions/Noob Questions
    Last Post: 10-08-2012, 08:36 AM
  4. Fog lights Burnt out!!
    By Osvaldo831 in forum Visual/Body Modifications
    Last Post: 07-05-2012, 04:30 AM
  5. burnt red!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 02-11-2010, 06:29 PM
