Im thinking 1/2 bard, anyone before i order one?
I think its 5/8 but you dont really need one. Just hold the garden hose up agaist the heater hose. It may be a little more wet that way but it is quick and you can dry
Sent from my SCH-R970 using Tapatalk
Well after 3 16hr night shifts in a row I just got around to doing the flush. Figured how cold its about to get Id rather postpone sleep then freeze next week. Anyways ended up using a little air pump I use to inflate tires. Back flushed it and tons of junk came out. Filled up the core with water then blasted it with air again. Did it a few times going both ways and boom heat is back. Thanks for all your help
I might end up making another thread for this question but ill ask here first. Where is that elbow thats for HVAC condensation? Do you get it from the top or bottom? My googling says it should be on the firewall near the front of the engine but I couldn't find it. Anyone got a pic handy?
its on the fire wall, but under the car really, about dead center. you'll see a rubber hose with a 90 deg elbow sticking out.
