Thread: Rough Idle After Replacing Radiator
Results 1 to 17 of 17
  1. #1 Rough Idle After Replacing Radiator
    SE Level Member Paintball0027's Avatar
    Jul 2010
    Michigan
    Car: 2001 Grand Prix GT - 199k, basically stock.
    My car was overheating pretty badly, so I went to replace the radiator and noticed that the motor mount on the passenger dog bone was broken clean off. So while doing the radiator I replaced that. Once everything was back together, the car sounded good and ran good for about a week. Then randomly it would have a chopping idle while driving, and it seemed to be loosing power. This happened more and more. Now it's really rough.
    Once I start the car, it sits at like 1300 RPM's until I put it into gear or the car is warm.
    While sitting still, the idle jumps from around 800 down to 650 and back forth. If I put the car in neutral, it seems to help a little bit for awhile, then it starts to idle down to 650 and back to 800 again.
    While driving, it feels like I have no power and it takes forever to accelerate and the engine on and off jumps really hard. But randomly it will stop and the car will drive just fine and have no issues with the idle. There have been no codes or SES light showing.
    I'm not sure if I should start with plugs and wires and go from there or what.
    2007 Pontiac Grand Prix GXP - ZZP exhaust,1999 Pontiac Grand Prix GT -Falken Cinturato 828 tires,GMPP performance handling kit,oversized front sway bar, front strut tower brace, tubular trailing arms, spectre cold air, 180* drilled thermostat, ZZP Racing transmission with 3.29 gears, 4th gear hardened shaft, shortened dog bones.
  2. #2 Re: Rough Idle After Replacing Radiator
    sounds like a vac leak. spray some carb cleaner around the engine at the vac lines when its at idle. if the idle jumps up you found you vac lea area.
  3. #3 Re: Rough Idle After Replacing Radiator
    Jul 2010
    Michigan
    I sprayed all around the throttle body vac line and the lines that go close to the MAP and fuel rail and nothing happened. I unplugged and checked the edges for cracks and didn't find anything. The vacuum seemed strong. It seemed to be running a little better after messing around with the lines. Going to drive it tomorrow and figure out if it fixed anything.
  4. #4 Re: Rough Idle After Replacing Radiator
    you could try un plugging the maf, then starting up the car. if it runs better the maf is bad.
  5. #5 Re: Rough Idle After Replacing Radiator
    Jul 2010
    Michigan
    That was the absolute first thing I checked. It ran kind of close to the same really, which makes me wonder if that's bad still. Because the car shouldn't start with the MAF unplugged. Or if it's started and unplug the MAF it should turn right off, right?
  6. #6 Re: Rough Idle After Replacing Radiator
    you unplug it then fire the car up it now runs in closed loop, like when its cold. if it runs better the maf is bad. in your case id say its fine.
    you never want to unplug it when its running.
  7. #7 Re: Rough Idle After Replacing Radiator
    Jul 2010
    Michigan
    So I tried unplugging the MAF again and it kind of ran better. Not too much better, but it ran a little better.
    I forgot to mention that the sensor that is in the air intake was missing on my car. I also replaced that when I did my radiator. Any reason that might have acted up and messed the MAF up?
  8. #8 Re: Rough Idle After Replacing Radiator
    not sure, check around the rad, make sure you didnt mess up some wires or a vac line. one may run across the front of the car rad support. if that broke it could cause a vac leak.
  9. #9 Re: Rough Idle After Replacing Radiator
    Jul 2010
    Michigan
    So I replaced all the vacuum lines on top of the engine by the fuel rail and it seemed to idle good and run fine. But after about 5 min of driving it started to have some hesitation.
  10. #10 Re: Rough Idle After Replacing Radiator
    Oct 2013
    NC
    You had mentioned replacing plugs and wires. Are they old? If so, change them out.
  11. #11 Re: Rough Idle After Replacing Radiator
    Jul 2010
    Michigan
    Not quite sure how old they are. Just bought the car this past summer.
  12. #12 Re: Rough Idle After Replacing Radiator
    Jul 2010
    Michigan
    So I just found out that the SES light isn't even working. So I went in and had it scanned. Over 20 codes came up.
    Here are the following codes:
    P0137
    P0141
    P0201
    P0300
    P0420
    P0650
    P1107
    P0102
    P0107
    P0113
    Seems like a lot of these are caused by one thing. So far I've tried unplugging the MAF and even replaced it with another one I had (new) sitting around. Didn't seem to make a difference in how it ran. Swapped the MAP out with another one I had and it made it a little better, but not completely. And I've changed the vacuum lines on the top of the engine that run along the fuel rail.
    Hopefully I can get some insight on this, it's driving me insane.
    Thanks.
  13. #13 Re: Rough Idle After Replacing Radiator
    Shoot man, honestly when I see a car with that many codes I would clear them all and drive the car untill the light popped up again and deal with the code(s) that came up first.
  14. #14 Re: Rough Idle After Replacing Radiator
    http://www.gmforum.com/obd-ii-troubl.../p0650-286007/ this po650 worries me. bad pcm, and that could be the whole cause of the rest.
    hows your grounds? the battery cables are clean and tight, the grounds on the tranny bell housing are good and tight, the wires are tight in the eyelets still?
  15. #15 Re: Rough Idle After Replacing Radiator
    Pennsylvania
    I second what Scottydoggs said. Did you screw with any electrical grounds? I moved my battery ground like half a foot to a different location because the bolt sheared off in the factory hole, and it totally screwed everything up for like a month. My gauges were wacky, abs lights, trac control lights, charging system failure, etc.
    I finally had to drill and tap a new hole right next to the old one and everything magically got fixed.
    Sport Edition Kv5 18x8
  16. #16 Re: Rough Idle After Replacing Radiator
    Nov 2013
    Central VA
    I had a PCM issue last year on a different vehicle that caused a flurry of codes most of which referenced low voltage or circuit failure similar to what you have, I agree with Scottydoggs that you should troubleshoot the PCM first as it could be the root cause.
    In my case a capacitor on the PCM had leaked and corroded away a trace on the circuit board. Replacing the capacitors that leaked and soldering a jumper around the corroded trace solved the problem. The trace must have been part of the PCM that enabled power to the input circuits that were flagged as circuit failure or low voltage codes.
  17. #17 Re: Rough Idle After Replacing Radiator
    Jul 2010
    Michigan
    So I went and had the codes cleared. Turns out it was just the misfire on cylinder 1. The injector was throwing a code, too. So I unplugged the wire from the spark plug end, looked at it, put it on nice and good and checked to make sure all the wires around the injector on cylinder 1 was plugged in right. Went to start it and it ran just fine.
    Thanks for all the input.
  1. low rough idle
    By lewis1952 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-07-2013, 03:51 AM
  2. need a how to on replacing my radiator, 97 GT
    By Mikey Bonefas in forum General Tech Discussion
    Last Post: 08-22-2012, 08:36 PM
  3. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  4. Replacing radiator
    By boothe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 10:34 PM
  5. replacing the OEM radiator
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2008, 06:09 PM
