Thread: Coolant Leak
Results 1 to 9 of 9
  1. #1 Coolant Leak
    Banned
    Oct 2013
    Moorhead, MN
    Car is running.
    I've got a moderate/light Coolant leak running off of my power steering pump. It only does it while the engine is running but I can't tell where it's coming from.
    I replaced the elbows with aluminum ones, installed new Felpro aluminum LIM gaskets, checked the LIM bolts, and checked my hoses... Nothing.
    Maybe the oring rolled up on the elbow? Maybe a wrong bolt?
  2. #2 Re: Coolant Leak
    waterpump?
  3. #3 Re: Coolant Leak
    Banned
    Oct 2013
    Moorhead, MN
    Water Pump was replaced with the rebuild. Bosch.
    http://www.rockauto.com/catalog/more...141&cc=1359345
  4. #4 Re: Coolant Leak
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    front cover gasket?
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Coolant Leak
    Banned
    Oct 2013
    Moorhead, MN
    I may have used a wrong bolt length putting the timing cover and/or water pump back together. I'm trying to find the bolt specs as we speak but... Ugh.
    I'm going to take the passenger wheel/shield off tomorrow to get a better look.
    I have some replacement bolts on the way (Bonnevillesunlimited.com) just in case.
  6. #6 Re: Coolant Leak
    Did you put sealant on the bolts?
  7. #7 Re: Coolant Leak
    It could easily be if you didn't clean out the holes for the elbows and didn't lube them for reinstall.
    On bolts..
    The 4 long WP ones do most of the top of the cover. Then there's two about 1.5" right in the arm pits of the cover. (under outlet for hose to rad and other side to back) from there... if you get the crank sensor shield on.. you likely have all the rest correct. And like Dan said.. did you seal them? Cause they go into the water jacket.
  8. #8 Re: Coolant Leak
    Banned
    Oct 2013
    Moorhead, MN
    Dumb. I got it.
    Heater hoses were in place. Clamp was tightened on upper but not lower.
    Fixed!
    I'm not sure if the thermostat is opening up though. I'll probably remove the 180* I got and go back to the 195* anyways.
  9. #9 Re: Coolant Leak
    Gotta love those ID10T errors and yeah you are probably better off with the 195 anyway.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. Coolant Leak
    By Thenerveman in forum General Tech Discussion
    Last Post: 08-01-2013, 06:45 AM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Coolant leak
    By gentrymartin in forum General Tech Discussion
    Last Post: 03-12-2012, 02:51 PM
  5. Coolant Leak..help
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-07-2009, 10:56 PM
