Thread: misfire on cylinder 5
Results 1 to 7 of 7
  1. #1 misfire on cylinder 5
    Sep 2012
    fort Wayne, in
    Ok so I went to a shop and got it lived scanned and number 5 was horrible. I'm guessing it might be the injectors so I took a straighthead screw driver to it and it sounded like it was clicking right but I know that doesnt tell me if its weak. Is there any place besides a shop that I can take it to, to get a ohm reading in them?
  2. #2 Re: misfire on cylinder 5
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Check the spark plug first. It's the front bank so it should take you no more than a few to check it. It'll tell you more than trying to blindly figure out what causes it.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  3. #3 Re: misfire on cylinder 5
    Sep 2012
    fort Wayne, in
    I just replaced the wires and sparkies about a month ago with copper plugs and delphi wires so. It said bank 1 running lean so I swapped a coil with a newer one but it went back to the same feeling after a few days. Just feeling the shaking and hesitant accelerating. It also doesn't get up and go if I floor it, it doesn't ramp up right away to higher rpms it gradually climbs up into speed
  4. #4 Re: misfire on cylinder 5
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Is your car stock, if not check the gap on ur plugs , 0.60 for stock and bit lower if modded
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  5. #5 Re: misfire on cylinder 5
    Sep 2012
    fort Wayne, in
    Im pretty sure they were pregapped I got them from AutoZone
  6. #6 Re: misfire on cylinder 5
    Jan 2009
    Make sure they are gapped correctly, many times they are not gapped correctly from the store. Which plugs are you running and is the car stock?
  7. #7 Re: misfire on cylinder 5
    Sep 2012
    fort Wayne, in
    Yes the car is stock And they were ac delcos copper plugs
  1. Misfire on cylinder 3 and 4
    By bhuyser in forum General Tech Discussion
    Last Post: 09-08-2011, 11:17 AM
  2. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
