So I have a '04 NA GP with 161k on it and its had a number of issues with it, mileage related and I just want to get an idea of what I might expect in the near future what I could expect to go wrong, here's a list of whats been done
coolant elbows, LIM gasket, water pump, alternator, thermostat, rad flush, coolant sensor, belt, plugs & wires, rear caliper (ebrake BF leak), crank sensor
I'm due to swap out one of the transmission lines which is leaking and I have a rear hub I need to change as well, bad abs/trac sensor
My main question is what else should I be on the lookout for or expect to go bad as I want to keep it around for awhile...
injectos, MAF, TPS, idle control valve, HG, what should i be worried about lol, thanks
