Thread: High Mileage Grand Prix Expected Problems
Results 1 to 2 of 2
  1. #1 High Mileage Grand Prix Expected Problems
    May 2012
    Bloomington, IN
    So I have a '04 NA GP with 161k on it and its had a number of issues with it, mileage related and I just want to get an idea of what I might expect in the near future what I could expect to go wrong, here's a list of whats been done
    coolant elbows, LIM gasket, water pump, alternator, thermostat, rad flush, coolant sensor, belt, plugs & wires, rear caliper (ebrake BF leak), crank sensor
    I'm due to swap out one of the transmission lines which is leaking and I have a rear hub I need to change as well, bad abs/trac sensor
    My main question is what else should I be on the lookout for or expect to go bad as I want to keep it around for awhile...
    injectos, MAF, TPS, idle control valve, HG, what should i be worried about lol, thanks
  2. #2 Re: High Mileage Grand Prix Expected Problems
    you already got the coolant elbows and LIM gaskets changed which tends to leak after a while. might be a good idea to change the valve cover gaskets as well as they tend to crack and leak. since you're planning on changing one of the trans lines might as well drop the pan and change the pan gasket and add in new fluid for what was drained fro the pan. this is not to be confused with a trans flush! HG on these cars tend to last a long while. my motor's an L67 though but gets runned hard and it has over 200k plus miles.
    can also check the lower motor mount and trans mount as well as the control arms and ball joints for any play.
  1. High Mileage 06 Grand Prix - Yes or No?
    By aja2150 in forum General Grand Prix Discussion
    Last Post: 08-25-2013, 09:39 AM
  2. Light mods for high mileage
    By ILoveAudi in forum Introductions/Noob Questions
    Last Post: 07-11-2013, 01:20 PM
  3. Replies: 2
    Last Post: 03-09-2013, 10:10 PM
  4. High Mileage
    By jetscrazy44 in forum The Rant Forum
    Last Post: 08-02-2010, 06:19 AM
  5. Tune Up Advice, Just bought High Mileage Grand Prix GT
    By anicolay in forum General Tech Discussion
    Last Post: 04-29-2009, 02:57 PM
