Thread: ignition coils
Results 1 to 11 of 11
  1. #1 ignition coils
    Sep 2012
    fort Wayne, in
    For the car scanned and it said cylinder 5 was misfiring horribly. So I went and got a used coil pack but I'm wondering what the order was for coils because I was told one of the coils would be causing the misfire because the idle was pretty rough. I just put in pregapped copper plugs and Delphi wires. But I put the newer coil on and not running perfect but better. Ideas?
  2. #2 Re: ignition coils
    St. Louis
    Check your plugwire order.
    See this thread for proper order--> http://www.grandprixforums.net/showt...t=firing+order
  3. #3 Re: ignition coils
    Sep 2012
    fort Wayne, in
    So this might be a dumb question but the coils have numbers on them say I put them back In order But say I had two 2&5 coil packs and used them for two different spots would that be bad or do they have to be all different?
  4. #4 Re: ignition coils
    the numbers on the coils are only there to guide you when putting the wires back on, you can swap the coils around. they dont know they have #'s on them.
    you can take them and swap them around, as long as the wires are in the right place for each spark plug. so dont follow the #'s on them if you moved them.
  5. #5 Re: ignition coils
    Sep 2012
    fort Wayne, in
    So the order is 1-6-5-4-3-2
    Do I start the 1 wire on the front then work my way back and end with 2 or vise versa?
  6. #6 Re: ignition coils
    as long as your wires are in this order you're fine.
  7. #7 Re: ignition coils
    Sep 2012
    fort Wayne, in
    Ok so I switched the coil that fires cylinder 5 with a newer coil alittle better but not running smooth I can still feel a little jog at 0-10 while stopping but nothing like it was. I made sure the order was right. Since its running better i doubt the coil is junk. Any ideas? I know my exhaust resignator is shot but would that change my idle at all?
  8. #8 Re: ignition coils
    St. Louis
    Have you scanned again to see if any misfires are happening still? Might be an injector.
  9. #9 Re: ignition coils
    Sep 2012
    fort Wayne, in
    I got lucky with the mechanic doing the scanner for free I don't know of a place that uses a live scanner to check for misfires. If one injector was going bad wouldn't they all?
  10. #10 Re: ignition coils
    Nov 2011
    NY
    If you get a nail in one tire... does all four then go flat?
    lol... Sorry, I had to!
    But no, not necessarily (all going bad at same time).
    That said, if I had a problem with an injector, I would rebuild, or replace them all, but that's just me.
  11. #11 Re: ignition coils
    Dec 2010
    DMV
    Yup, just had this exact issue. Check the injector.
    Sent from my HTC One using Tapatalk 2
  1. Ignition Coils
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2013, 10:05 PM
  2. MSD ignition coils
    By MikeCimp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 09:37 AM
  3. msd ignition coils?
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 03-07-2012, 05:02 PM
  4. Exhaust/MSD ignition coils; to do or not to do?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 10-04-2009, 09:41 PM
  5. MSD Ignition Coils
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 10:18 AM
