Thread: How to get ball joint off and new one on
Results 1 to 8 of 8
  1. #1 How to get ball joint off and new one on
    Feb 2013
    Minnesota
    So it can time to replace the drivers side ball joint in my 01 GT. I have everything out of the way but it wasn't until then i noticed that the original ball joint is rivited in. What's the best way to punch or drill those out? Also, how do I know where to drill bigger holes so the new ball joint can be bolted on? Or does that really matter if it isn't perfectly placed? Thanks!
  2. #2 Re: How to get ball joint off and new one on
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    You have to drill them out. Its best if you have a drill press to make a straight thru hole. The hole does not need to be made bigger either. That will just cause alignment issues. Unless you just buy a control arm with a ball joint in it already.
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: How to get ball joint off and new one on
    Nov 2011
    NY
    You can drill them, the cost of a BJoint is about half what it would cost for an entirely new control arm. Decisions decisions...
  4. #4 Re: How to get ball joint off and new one on
    Grind an x in them and then use an air hammer and chisel the head off the rivet then punch it though. With a good air compressor it'll take about 5 min.
  5. #5 Re: How to get ball joint off and new one on
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Used a hand drill. Worked fine on mine!
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  6. #6 Re: How to get ball joint off and new one on
    Nov 2012
    Tennessee
    just get a drill bit a little smaller than the head of the rivet and drill them out. the new one should come with bolts and you just bolt the new one in....
  7. #7 Re: How to get ball joint off and new one on
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    if the balljoint needs to be replaced what do the LCA's rubber bushing look like?
    the balljoints on my car are good, the rubber bushing not so much........
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  8. #8 Re: How to get ball joint off and new one on
    Replacing just the ball joints on these cars is kind of dumb, because if the ball joint is shot I'm willing to bet the bushings aren't much better. Why not spend another $20-$25 and you can get the entire lower control arm with all new bushings. Save yourself some time and money and just get a lower control arm. Last I checked Rock Auto had the Moogs for like $42.
  1. 97 ball joint
    By jc71corvette2 in forum Introductions/Noob Questions
    Last Post: 10-02-2013, 11:25 AM
  2. Ball joint help
    By geetee in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2011, 05:23 PM
  3. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
  4. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  5. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
