Thread: P0300 - Random Multiple Cylinder Misfire
Results 1 to 12 of 12
  1. #1 P0300 - Random Multiple Cylinder Misfire
    Oct 2013
    Clovis, California USA
    2000 Buick LeSabre
    I'm starting this thread in case someone is able to help. This just happened today while driving on the freeway. The car had only been driven for about 10 minutes after start up. I was supposed to shut the engine down immediately to avoid catalytic converter damage, but I chickened out and drove the car the rest of the way home - about 1 mile. The engine was running very rough and would barely idle. Once I got it off idle, the engine would smooth out. The catalytic converter was ticking very loudly after I got the car home and shut off the engine. Also, there was a strong burning candle wax smell present in the air. Recent work done was a rear rocker arm cover gasket replacement and the two coolant elbows were replaced. I did the work myself. Today when I got the car home, I checked and double checked to make sure everything is plugged in and hooked up. Everything appears to be well connected.
    Thank you for your time and consideration.
  2. #2 Re: P0300 - Random Multiple Cylinder Misfire
    How old are the spark plugs?
    Maybe a coil pack died or the ICM is faulty, hard to say with out some testing.
  3. #3 Re: P0300 - Random Multiple Cylinder Misfire
    Oct 2013
    Spark plugs were replaced on October 11, 2010. ACDelco 41-101 Iridium.
    I also installed new Delphi ignition wires on the same day.
    Work was done by me.
  4. #4 Re: P0300 - Random Multiple Cylinder Misfire
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    How many miles on the catalytic converter?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: P0300 - Random Multiple Cylinder Misfire
    how many miles since that tune up?
    does the engine sound like a vacuum with a full bag when you floor it? like louder from the intake but not in a good way. if so the cat could be clogged. how many miles do you have there?
  6. #6 Re: P0300 - Random Multiple Cylinder Misfire
    Oct 2013
    Quote Originally Posted by EJOUIE View Post
    The car has over 112,000 miles on the clock and the catalytic converter is original.
    I haven't floored it because of how rough it runs. The one thing I did do is unplug the pre-catalytic oxygen sensor from the harness and started the engine up. Some guy on another forum wanted me to do that. The engine continued to run real rough and I noticed right away that the smell of the exhaust was extremely rich. I shut the engine off right away after that to avoid doing any further damage to the catalytic converter.
    Thank you guys for your help. I appreciate it very much.
  7. #7 Re: P0300 - Random Multiple Cylinder Misfire
    how many miles when you did the tune up last? it was 3 years ago now.
    is the check engine light on?
  8. #8 Re: P0300 - Random Multiple Cylinder Misfire
    Oct 2013
    Yes, the last tune up was 3 years ago at about 88,000 miles. I take very good care of the car. Up until today it's been a very good running and dependable car. The only thing it's ever needed was an EGR valve, A/C compressor, front CV axles, front hubs, front outer tie rod ends, brakes, front transmission mount, right motor mount, MAP sensor, and fluid changes. All work done by myself. Just recently before this latest episode, the idle was starting to get jittery. Not rough, but jittery. So I took the air intake hose off and shined the flashlight down into the throttle body. Everything on this side of the butterfly is spotless. I then took the MAF sensor off to see if its wires were dirty; it was spotless inside. So what I did then is go ahead and clean the Idle Air Control Valve; it was coated with black soot. Idle quality got a little bit better after that, but not much. The check engine light is on now and it was flashing when I was driving it earlier today on the freeway. From what I understand, the only time the check engine light will flash is if the misfire is bad enough to cause catalytic converter damage. Thank you for your help sir.
  9. #9 Re: P0300 - Random Multiple Cylinder Misfire
    flashing cel usually leads to a tune up, or clogged cat.
    you can remove the up stream o2, this will make a nice exhaust leak, but if it feels and runs better the cats clogged up.
    and if you open up the flap in the TB behind it is filthy for sure. the back side is what needs to be cleaned.
  10. #10 Re: P0300 - Random Multiple Cylinder Misfire
    Newnan, GA
    Sounds to me like the cat is clogged. Might as well replace the entire downpipe which would get rid of that stupid U bend.
  11. #11 Re: P0300 - Random Multiple Cylinder Misfire
    Jun 2011
    Texas
    You can check spark output for each cylinder at the coil pack. Get all 6 wires loose before you start the car, then pull off each wire one at a time with the engine at idle. You are looking for 2 things a good strong blue spark, and the idle to change with every wire you remove. You do not want to grab too close to the end of the wire or the spark will go through you and "bite" you as I say. This will lead you to which cylinder is not contributing.
  12. #12 Re: P0300 - Random Multiple Cylinder Misfire
    Oct 2013
    I ended up having to replace the Ignition Control Module. It wasn't firing cylinders 1 and 4.
  1. 97 gtp multiple cylinder misfire help.
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2012, 11:40 AM
  2. P0300 Code. Random Misfire NEED HELP!
    By JcGTP39 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2011, 10:12 PM
  3. random misfire P0300, many new parts
    By MarkB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 11:10 PM
  4. Random multiple cylinder misfire
    By sunfiregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 08:58 PM
  5. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
