Thread: tube inside upper intake
Results 1 to 6 of 6
  1. #1 tube inside upper intake
    SE Level Member chadace17's Avatar
    Aug 2013
    upstate ny
    Does anyone know what the tube inside the intake is for.. it's clipped to the old gasket and not the new one..
  2. #2 Re: tube inside upper intake
    Omaha, NE
    It's purpose is to bring the oil vapor from the PCV (at the passenger end of the manifold) into the middle of the LIM so it doesn't deposit it all in one area. Doesn't really do much beyond sit there and is clipped onto the gasket.
    Some people keep them, some toss them out. I've done both and didn't notice a difference either way.
  3. #3 Re: tube inside upper intake
    Mar 2013
    Cleveland
    I didn't re-install mine. I haven't seen any negative effects, it's been about 8 months.
  4. #4 Re: tube inside upper intake
    Same.
    I just threw mine out.
    You can also cut the runners that slide out of the upper manifold in half and glue them back together for a homemade HV3 Insert that ZZP sells for over $200~.
  5. #5 Re: tube inside upper intake
    Buffalo NY
    Would the glue hold up in the heat? I know that the air intake would technically cool it off
  6. #6 Re: tube inside upper intake
    Pennsylvania, USA
    Yeah, I wouldn't put glue in my intake personally.
  1. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  2. Stock airbox and intake tube for 00 gt
    By GPrixGT00 in forum Buy/Sell Other/Misc
    Last Post: 01-23-2012, 07:05 PM
  3. Stock intake tube?
    By 99GTPzilla in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2010, 08:27 PM
  4. Is there to be a tube INSIDE the overflow tank?
    By RM97 in forum General Tech Discussion
    Last Post: 05-15-2009, 08:29 PM
