Read the whole thing for the most part, but still have a couple of questions on top swapping my 02 GT.
First of all, I bought a whole motor out of a 97 gtp, but wanted the higher comp, so im top swapping.
1. I've read that the injector clips changed from 97 to 02. Can i just cut the clips off the 97 harness and solder them on my 02?
2. I'm looking at the top end gasket set on rock auto from fel pro, it appears to cover everything as far as gaskets go, is this correct? I plan on ARP headstuds and rocker bolts.
3. Do i need to switch the MAP sensor clip?I think thats all the questions i have for now. Im sure ill come up with a few more thoughThanks!
