Thread: Big oil leak at the oil pressure sensor!
Results 1 to 5 of 5
  1. #1 Big oil leak at the oil pressure sensor!
    Apr 2009
    vegas
    99 3.8 na oil started leaking quite a few drops, and then today it is leaking enough to puddle oil on the ground. I looked and it looks like oil is heavily dripping from the plug on the oil pressure sensor that is screwed in to the oil filter mount. I looks like the oil is coming right out of the plug! Has any one experienced this before? Tomorrow I will pick up a new sensor and replace it.
  2. #2 Big oil leak at the oil pressure sensor!
    Ask Scotty he's the poster child of replacing those.
    04 Comp G.
  3. #3 Re: Big oil leak at the oil pressure sensor!
    Common issue.
    Replace it or the plug the hole, the sensor is useless as it comes on with 5 psi and by then the motor has already died.
  4. #4 Re: Big oil leak at the oil pressure sensor!
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Just went threw it on my 2000 Grand Prix .. Make sure to get the socket it's only like 5$
  5. #5 Re: Big oil leak at the oil pressure sensor!
    St. Louis
    Yep, happens often as FFDP stated. I replaced it with one of these at the other end on the A-pillar. True gauge FTW.
  1. Oil Pressure Sensor Location
    By bjperez in forum Introductions/Noob Questions
    Last Post: 03-01-2013, 09:30 PM
  2. CEL Oil Pressure Sensor
    By Eddie Jackson in forum 5.3L V8 (LS4)
    Last Post: 03-01-2013, 09:03 PM
  3. oil pressure sensor
    By Clarence Hullinger in forum Introductions/Noob Questions
    Last Post: 06-07-2012, 02:44 PM
  4. Oil Pressure Sensor
    By confused in forum General Tech Discussion
    Last Post: 02-18-2012, 03:07 PM
  5. Oil Pressure Sensor
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2008, 12:11 PM
