Thread: Swapping out the Radiator, any words of wisdom?
Results 1 to 5 of 5
  1. #1 Swapping out the Radiator, any words of wisdom?
    Sep 2012
    Chisago Lakes, MN
    Friday morning my daughter is coming over, her radiator is leaking apparently. So we're going to put in a new Radiator. I already picked up the new one at Napa. Its got a few loose parts for mounting etc. I've done a few of these before in previous cars, but I just wanted to see if you guys may have some insight on this particular job. !999 GP, 3.8 NON SC.
    Any tips are appreciated, I've got other things I'd like to get done Friday as well...
  2. #2 Re: Swapping out the Radiator, any words of wisdom?
    Pretty easy.
    Remove dog bones and mounts, unplug the fans, undo the 4 bolts holding it to the rad. Then remove the lower and upper rad hoses from the raditor itself. The trans cooler lines have small clips holding them in, a angle pick gets them out easy. On the bottom there is a clip/holder that the cooler lines run it, just a simple pop and they are free.
    Thats pretty much it, the rad will lift right out.
  3. #3 Re: Swapping out the Radiator, any words of wisdom?
    Sep 2012
    Chisago Lakes, MN
    Thanks, ffdp, glad to hear its "Pretty easy", I'll be the judge of that...
    I'll let you know how it goes.
  4. #4 Re: Swapping out the Radiator, any words of wisdom?
    I only say "pretty easy" because I've done it twice already on my own car during the same repair lol.
    I got good at getting it out quick.
  5. #5 Re: Swapping out the Radiator, any words of wisdom?
    Sep 2012
    Chisago Lakes, MN
    Well the deed is done. i guess it did fall into the "Pretty Easy" category. It took me longer than I had hoped, but doesn't it always. I ended up having to pull the battery as well in order to get it out. The only hang up I had was the low coolent sensor wanted to leak when I refilled. I went to napa and got a couple orings and it was good to go.
  1. swapping radiator on a 2001
    By tech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2013, 07:02 PM
  2. Wisdom teeth
    By Pontiac Man in forum Off Topic Discussion
    Last Post: 03-18-2012, 12:26 AM
  3. Stut mounts going, request your wisdom.
    By KZOO3800 in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2011, 09:38 PM
  4. I got my wisdom teeth pulled
    By Sandmaster in forum Off Topic Discussion
    Last Post: 04-24-2010, 01:48 PM
  5. Wisdom Teeth
    By eb08gprix in forum The Rant Forum
    Last Post: 07-09-2009, 12:04 PM
