Thread: Wizair intake and 98 coolant bottle position
Results 1 to 4 of 4
  1. #1 Wizair intake and 98 coolant bottle position
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So I got a great deal on a Wizair intake but also have a 98. Do I have to change to a 99+ coolant bottle? There's absolutely no way that the box will fit over the one I already have? And is there a write up anywhere on how to do the switch? I looked through the how to section and used the search feature but wasn't able to find anything. Maybe I overlooked it but if not could someone give me a walk through on how to do it? Thanks.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Wizair intake and 98 coolant bottle position
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    SUUUPER easy ! , get the old coolant bottle out, pull the reservoir hose . Install new bottle on passenger strut (drill holes with bit) install screws over new coolant bottle install reservoir hose to new bottle. Wbodystore sells new one for $40 . Go for it easy install.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  3. #3 Re: Wizair intake and 98 coolant bottle position
    SWPA
    $40 is way too much for a new bottle. I got one straight from GM for around $20.
  4. #4 Re: Wizair intake and 98 coolant bottle position
    Buffalo, NY
    If it's that easy I guess I'll just man up and do it haha. Was just trying to be lazy. I'll hit a yard and hopefully I can find one if not I'll check the GM dealer first. Thanks guys.
