Thread: p0171 and p0300 please help.
Results 1 to 18 of 18
  1. #1 p0171 and p0300 please help.
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I hv an 08 na grand prix. I started it the other day and it ran like a bag of poop. I brang it In to the shop and it showed up with two codes. 171 & 300. Bank one running lean and multiple random misfire. The coil that feeds number 2 $5 coil pack wasn't firing. So I changed the coil with no luck. I chevked the pcv cleaned the tb. My battery terminals were corroded bad so I disconnected the battery cables to clean em up and now it won't start at all. It will turn over buf that's it. I started the first time after disconnecting the battery and it ran for 6 seconds and died.
    I have no idea were to look now. Any help would be appreciated. It has 133000kms and well maintained.
  2. #2 Re: p0171 and p0300 please help.
    You have a vacuum leak. Try holding the throttle down a little while starting
  3. #3 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    I tried that already. Doesn't even sound like it wants to start. I'm not sure were my vacum lines are. I was thinking mb my cam sensor
  4. #4 Re: p0171 and p0300 please help.
    the p0171 is a vacuum leak. Spray some starting fluid in the tb and try to start it again.
  5. #5 Re: p0171 and p0300 please help.
    I'd try unplugging the MAF and see if it wants to start.
  6. #6 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    Which one is the maf sensor?
  7. #7 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    This is driving me nuts. It ran before I disconnected the battery I checked my fuses. Just can't check the big square ones.
  8. #8 Re: p0171 and p0300 please help.
    MAF is in the air intake tube.
  9. #9 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    Is that the sensor in the rubber intake. The small one or is it the big sensor just before the intake
  10. #10 Re: p0171 and p0300 please help.
    big one
  11. #11 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    Just tried it with no luck. A couple weeks before this happened I noticed that I was losing power slowly. The day before my problems happened I stepped on it and it took off slow and sounded like I had a leak in my xhaust manifold but I don't.... just thinking now maybe my cat.
  12. #12 Re: p0171 and p0300 please help.
    try unbolting the dp and starting it or pulling the front 02 out.
  13. #13 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    I have a appointment friday morning. I hope its a cheap fix. Just trying to figure out whhy it won't run after a hard reset from my battery.
  14. #14 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    Thanks a lot dsmuts. Il try that now
  15. #15 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    I brang it to the garage and was told that my brand new coil don't work it was #2&#5 coil that wasn't working. So I purchased a new coil and Ippurchased a new icm. My question is the icm I bought isn't a gm or ac delco replacement. I bought one from napa for half the price, was this a good idea? I kno sumtimes our cars don't like cheap products. Can I mess sumthing up by using cheap electronic parts
  16. #16 Re: p0171 and p0300 please help.
    swap the new coil in, see how it does, if its still acting up put the new icm in. new parts should be ok. napa does sell good parts, so i dont think id worry about it to much.
  17. #17 Re: p0171 and p0300 please help.
    Nov 2011
    north bay, ontario
    Its running perfect again. Got all my power back. Not sure if I messed up my cat driving it a short distance w raw fuel being dumped in but that's the problem. For anyone hvn these codes remember this. Its important to come back here and post your solution s....
  18. #18 Re: p0171 and p0300 please help.
    Jan 2012
    FT Campbell, KY
    My fix was the flange sealing the tube to the valve.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  1. p0300
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2013, 07:27 PM
  2. P0300, P0171 issues. Lots of info logged+pics
    By deadsnake in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2013, 12:55 PM
  3. My P0300 discovery
    By mayoke in forum General Tech Discussion
    Last Post: 09-01-2011, 08:12 AM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
  5. p0300
    By fratzke7 in forum General Tech Discussion
    Last Post: 10-10-2008, 09:19 AM
