Thread: Starting engine problem
Results 1 to 13 of 13
  1. #1 Starting engine problem
    GTP Level Member Grandprix202's Avatar
    Apr 2013
    Fowlerville
    In my 04 gt N/A it has an issue of starting ever since I've had it. But the word thing is is that it seems to start up nice and strong on cold starts but it can't "grab" and start up strong after being driven or warm starts. It turns over but I just need to give it gas to get it to start when it's warm. Any ideas on what this could be?
  2. #2 Re: Starting engine problem
    start out with cleaning the TB. remove it to clean it.
  3. #3 Re: Starting engine problem
    Apr 2013
    Fowlerville
    What's the TB?
    Representing all the N/A out there. Fastest stock N/A you will ever come across.
  4. #4 Re: Starting engine problem
    ThrOttle body
  5. #5 Re: Starting engine problem
    Apr 2013
    Fowlerville
    Alright...I'm not much of a mechanic so what exactly is the throttle body and where is it located
  6. #6 Re: Starting engine problem
  7. #7 Re: Starting engine problem
    It has the rubber air intake tube connected to it.
  8. #8 Re: Starting engine problem
    Apr 2013
    Fowlerville
    Oh alright...is it hard to take apart and clean?
  9. #9 Re: Starting engine problem
    on that year you can clean it up pretty good left on the car, carb cleaner and a shop rag, take the air filter tube off, push that gold fliap open, then spray and wipe, behind the flap, and the outer wall, as well as the flap its self, on the back side and the edges.
    you can see the black ring on the gold part in the pic posted, you want all that off and clean. it will be very black behind that flap.
  10. #10 Re: Starting engine problem
    Apr 2013
    Fowlerville
    Alright doesn't sound to bad. Thanks for the advise I will update later to see if it helped at all thanks again guys!
  11. #11 Re: Starting engine problem
    04's are known for that not catching on the first start. GM has an updated calibration for it, but being its out of warranty you'd have to pay unless someone can flash your PCM.
  12. #12 Re: Starting engine problem
    04+ are only known for that if the have a dirty tb
  13. #13 Re: Starting engine problem
    Possibly true but I've never had a problem once I got a tune, and I just cleaned my dirty ass TB the other day. Literally filthy.
  1. starting problem. when go to start the engine will sometimes die
    By DirtDog in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2012, 12:32 PM
  2. Starting Problem
    By DevilDust in forum General Tech Discussion
    Last Post: 10-18-2011, 09:46 AM
  3. Starting Problem
    By bradycat101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 03:17 PM
  4. Starting problem....
    By greatAEorion in forum General Tech Discussion
    Last Post: 09-30-2009, 09:54 AM
  5. 06 GT SC starting problem
    By BHMJohn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2009, 11:38 PM
