Thread: Removal of Resonator
Results 1 to 20 of 31
  1. #1 Removal of Resonator
    SE Level Member KitRae's Avatar
    Jul 2012
    St. Catharines
    Just wondering if removing the Resonator would be a good thing or not. I heard that it improves performance, not by much, but would this make it sound a bit better? Any Ideas or suggestions?
    2002 Grand Prix GT 3.8L Naturally Aspirated
    - NGK Iridium Performance Spark Plugs
    - NGK 51031 Performance Spark Plug Wires
    - EPR Cross Drilled Performance Brakes & Ceramic Pads
  2. #2 Re: Removal of Resonator
    With a cat converter and stock mufflers you'd likely notice nothing except maybe at WOT, but I doubt you'd hear any real rasp from not having the res.
    Removing won't increase performance, so its best to just leave it.
  3. #3 Re: Removal of Resonator
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Just keep it on.
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  4. #4 Re: Removal of Resonator
    Most of the restriction in our exhaust is in the manifolds and the ubend. Everything else flows good till something like 300 whp.
  5. #5 Re: Removal of Resonator
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Resonator removal is for extra noise, provides no extra power
  6. #6 Re: Removal of Resonator
    Jul 2012
    St. Catharines
    OK, Thanks. What would be your suggestion for the Manifolds and U-Bend? Any particular brand that is better (cost effective) that you could suggest?
  7. #7 Re: Removal of Resonator
    Dec 2012
    Where 4T65E's were born
    A plog for the manifolds, and a u-bend delete can be done with a pipe and O2 fitting.
    You can also do headers instead of the plog, it costs a little more but you get everything, including deleting the u-bend. Speed daddy makes good ones for a good price of around $220
    Sold.
  8. #8 Re: Removal of Resonator
    Link in my signature.
    I suggest reading.
    Because doing this:
    Removal of Resonator.
    Is dumb.
  9. #9 Re: Removal of Resonator
    Nov 2011
    Indiana
    For the U-bend= ZZPerformance - Ubend Delete #ZZ-UBENDD
    As for headers, there's a few options to choose from. If you can spend the cash, ZZP and TOGS ( The other guys) are the most pricey but well made headers for our cars. There are other brands, like SLP, Pacesetters, ect as far as headers go. Most people on a budget get Speed Daddy headers off ebay. You will need some extra gaskets and clamps when you buy them, but they're currently the cheaper IIRC? Or buy a Plog from ZZP and a 3in DP.
  10. #10 Re: Removal of Resonator
    Dec 2012
    ^ yes on Grand Prix stock exhaust removing the resonator is a bad idea. However removing it on a quieter exhaust system yields almost no sound difference. We straight piped the resonator on our 3.8 impala, no sound difference from original setup that I can tell. It's a lot quieter than a res with a large hole, that's for sure.
    Sold.
  11. #11 Re: Removal of Resonator
    Probably because it was bypassing the mufflers.
    Regardless, a 3.8...even with stock mufflers sounds like crap without the resonator.
    Bar none. It needs one.
  12. #12 Re: Removal of Resonator
    Dec 2012
    Right. So if it goes, stick a glass pack in it's place.
    Sold.
  13. #13 Re: Removal of Resonator
    Aug 2011
    'Merica
    I ran no res for years with no sound difference....just saying
  14. #14 Re: Removal of Resonator
    Nov 2011
    Indiana
    It depends on your exhaust setup really. I have no res, and I will say it sounded alot better after removing the resonator than it did with a resonator. Went from a farty 4cyl type sound to a crappy v6 sound. No drone what so ever either. It all depends. If you're stock, just leave it.
  15. #15 Re: Removal of Resonator
    Dec 2012
    Sounds horrible.
    Sold.
  16. #16 Re: Removal of Resonator
    Nov 2011
    Indiana
    Ew.
  17. #17 Re: Removal of Resonator
    It's a fact.
    Only way you'd be able to get away with not having a resonator is a snail.
    It's not really a "like this or that"...it's a: your car buzzes and rasps and drones without one. Not to mention the 3800 exhaust blows anyways.
  18. #18 Re: Removal of Resonator
    Nov 2011
    Indiana
    Our cars do sound like poop, but I will say it doesn't rasp and drone without one. Do i need to make more videos of mine?
  19. #19 Re: Removal of Resonator
    Dec 2012
    We love videos and pics on these forums so yes.
    I don't agree on droning with res delete and stock mufflers. Rasp won't happen unless you're revving it or using the "manual shifting" where you're in a gear too low and let off the gas. So normal driving with res delete, you may not notice, especially if you're always in the car.
    Sold.
  20. #20 Re: Removal of Resonator
    Nov 2011
    Indiana
    These are like half a year old. Excuse the whining/clicking noise in the car, its my oil gauge.
  1. resonator
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2011, 06:14 PM
  2. resonator
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2011, 12:18 PM
  3. resonator
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 06-30-2010, 12:28 PM
  4. Resonator cut...
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:11 AM
  5. resonator vs no resonator
    By Toasty in forum General Tech Discussion
    Last Post: 05-09-2008, 08:24 AM
