Thread: Water pump change
Results 1 to 14 of 14
  1. #1 Water pump change
    Feb 2013
    Minnesota
    Currently changing the water pump in my 01 GT. what are the correct torque ratings for the water pumps bolts, and the pulley bolts? Or should i just get them snug?
  2. #2 Re: Water pump change
    There ya go bro http://www.grandprixforums.net/bolt-...ead-48823.html
    Most people just get them good and snug.
  3. #3 Re: Water pump change
    Personally I hate to torque those bolts because what if even at the correct TQ number they break.
    I choose to get them nice and tight/snug and leave them.
    Dont forget to use some thread sealant on the bolts that go into the coolant jackets.
  4. #4 Re: Water pump change
    what he said ^^ just tight. nothing crazy either.
    heres a tip if you did not know, break the 4 bolts on the w/p pulley loose before you take the belt off, make then tight after the belt is back on. or you'll have a hard time getting them off. or back on tight.
  5. #5 Re: Water pump change
    I've never broken a WP bolt. 13's are about 13ft lbs and the 10's are lower..
  6. #6 Re: Water pump change
    Feb 2013
    Minnesota
    Alright thanks! Currently I am having touble getting the power steering pully back into place. I can't seem to get te bolts in
  7. #7 Re: Water pump change
    those 2 bolts are fun, you can see the top hole a bit by looking over the top and looking at the back with the bolt sticking out, then line it up to the threaded hole. once one bolt is in the other is easy.
  8. #8 Re: Water pump change
    The power steering pump is even funner to get on when you hands are cold, you have to pee and your already pissed off.
  9. #9 Re: Water pump change
    The way I do a ps pump. Leave the bolts in it, push the lower bolt so the end is flush with the back of the pump. Now put your socket on the top bolt and push it all the way so it protrudes. I use my right hand on the socket and left on the back of the pump. Get the pump in the are where it should go.. you can feel it hit the hole with your right hand, start trying to thread it.. pull toward the pass side with the pump..you'll know quick if you got it started.. if so.. pivot the bottom of the pump toward the radiator and move your socket to the lower bolt, now use your left to pull the bottom of the pump toward the firewall until you feel the bolt drop into the hole.. thread away.
  10. #10 Re: Water pump change
    Feb 2013
    Minnesota
    I got her in yesterday after reading ScottyDogs post. I used my left hand to feel the bolt hole and used my right hand to guide it there. Toughest part of changing the pump was getting the lower steering back in! Lol
  11. #11 Re: Water pump change
    Do it enough times.. I've had a lot of practice and it's a second nature thing at this point..
  12. #12 Re: Water pump change
    my second time was easier then the first for sure.
  13. #13 Re: Water pump change
    You gotta work on more 3800's.. they are sooooo nice
  14. #14 Re: Water pump change
    i try to keep my working on the car as a need to basis.
  1. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  2. Water Pump?
    By Lowdown112 in forum General Grand Prix Discussion
    Last Post: 01-25-2013, 09:51 AM
  3. Water Pump
    By blaqdiamondz46 in forum General Tech Discussion
    Last Post: 11-11-2011, 03:29 PM
  4. Water pump
    By robblk04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2011, 03:18 PM
  5. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
