Thread: Need Help Bad
Results 1 to 9 of 9
  1. #1 Need Help Bad
    Jul 2013
    Atlanta
    In order to crank my 06 grand prix N/A i have to tap the gas but once i do that it runs fine. What could be the problem? ive been told fuel filter or MAF sensor. What do you all think?
  2. #2 Re: Need Help Bad
    Do you notice any issues while you are driving? Any CEL? Does the car bog down at all?
  3. #3 Re: Need Help Bad
    Jul 2013
    Atlanta
    its runs good while driving. I feel no change in getting up in rpms. Itll go for a v6.
  4. #4 Re: Need Help Bad
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    You mean you just need to tap the gas to get your car started? Clean your throttle body and your problem is solved, also while you are at it you should clean your MAF since it is right there and takes a few seconds.
  5. #5 Re: Need Help Bad
    Jul 2013
    Atlanta
    yea i just have to tap it. i will try it tomorrow and try to get back on here.
  6. #6 Re: Need Help Bad
    Oct 2011
    huntley
    Yea it happens on all grand prixs. I had to do mine a couple of months after I got my car. Just clean as much of the black off if the back side of the throttle body as you can and it will start up right away with no issues. Should take ya about 20 minutes to do probably if it is your first time
  7. #7 Re: Need Help Bad
    Pull the tb off the car and scrub it spotless
  8. #8 Re: Need Help Bad
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Be careful with the MAF...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  9. #9 Re: Need Help Bad
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Use MAF cleaner on the maf. nothing else on the maf.
    1997 Red GTP 182000 miles stock
bad
