Thread: Which one is heater inlet hose?
Results 1 to 9 of 9
fuzzbutt Which one is heater inlet... 04-04-2012, 06:43 PM
Scottydoggs Re: Which one is heater inlet... 04-04-2012, 06:47 PM
fuzzbutt Re: Which one is heater inlet... 04-05-2012, 01:57 AM
BillBoost37 Re: Which one is heater inlet... 04-05-2012, 05:19 AM
fuzzbutt Re: Which one is heater inlet... 04-06-2012, 12:02 AM
Flip97GTP Re: Which one is heater inlet... 07-11-2013, 02:58 AM
QUICKSILVER462 Re: Which one is heater inlet... 07-11-2013, 06:13 AM
Flip97GTP Re: Which one is heater inlet... 07-11-2013, 10:16 PM
Scottydoggs Re: Which one is heater inlet... 07-11-2013, 08:26 AM
  1. #1 Which one is heater inlet hose?
    SE Level Member fuzzbutt's Avatar
    fallbrook
    Hi, trying to install a flush kit and they say to cut the heater inlet hose. Both hoses run form firewall and both seem to go into the water pump but they don't want me cutting the water pump hose, just the heater INLET hose.
    Can't find a schematic for that. Any help please?
    Thanks!
    Steve
  2. #2 Re: Which one is heater inlet hose?
    it really wont matter which heater hose you tap into. the flush will still go everywhere.
    but im thinking the top hose on the fire wall is the one pumping into the heater core, the lower one is its return. 50/50 shot there lol
  3. #3 Re: Which one is heater inlet hose?
    fallbrook
    Hmm, just trying to do what the instructions say to do. You're probably right, though. Water flows all the way through so what's the difference? But just in case there's a one way valve or something crazy, I do need to ascertain the heater inlet hose. they both look like they run into the water pump but I'm sure one just goes to the top water jacket. Not sure, never did this one before..
    Any absolute, positively sure diagrams or anything on this?
    Thanks though.
  4. #4 Re: Which one is heater inlet hose?
    Pull one off.. have someone watch. You'll know quickly.
  5. #5 Re: Which one is heater inlet hose?
    fallbrook
    Ha! I just grabbed the top one coming out of the firewall and spliced it. Seems to work with the flush, probably as Scottiedogg said.
    However, I have worse problems than that with this pig. Only 118k of easy miles (with synthetic oil changes every 6k) and main seal is leaking and the head gasket blew. Now the starter won't crank probably due to water in the cylinder. Jeez, what next- locusts???
  6. #6 Re: Which one is heater inlet hose?
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    I getting ready to do this, this weekend, if the tropical storm doesn't come through :-( . I also, would like to now which of the heater hoses is the inlet hose but I have read it is the top hose.
  7. #7 Re: Which one is heater inlet hose?
    HUDSON
    First way to figure out which is "in" and "out" is you can turn the heater on, then feel which hose is hot/not as hot , the hotter one is "in", the cooler one is "out", another way: the larger hose is "in", smaller hose is "out", hot water expands, as it cools going though the H.E., it contracts.
  8. #8 Re: Which one is heater inlet hose?
    May 2013
    Quote Originally Posted by QUICKSILVER462 View Post
    This is the one I'm going with!
    Thanks fellas!
  9. #9 Re: Which one is heater inlet hose?
    there is no flow valve to the heater core. it flows coolant year round. so both hoses get hot all the time.
    this idea does work tho, start with a cold engine, fire it up, hold both hoses, witch ever one gets hot first is the one that flows into the core.
    or take both hoses off the fire wall, and fire the car up, you see the hose push coolant.
  1. Heater inlet hose
    By PatrickMcL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2010, 07:59 PM
  2. Motormite Heater Hose !!HElP!!
    By emitchell365 in forum General Tech Discussion
    Last Post: 09-12-2009, 05:41 PM
  3. Which is the hose the goes to heater core?
    By DesertFox in forum General Tech Discussion
    Last Post: 05-16-2009, 06:08 PM
  4. 2005 Grand Prix heater inlet hose?
    By xctment in forum General Tech Discussion
    Last Post: 01-17-2009, 08:43 PM
  5. location of heater inlet hose on 1994 grand prix?
    By bimple in forum General Tech Discussion
    Last Post: 01-01-2009, 06:37 PM
