Thread: wont start when warm
Results 1 to 6 of 6
  1. #1 wont start when warm
    Jul 2013
    Vestal, NY
    My 03 grand Prix sometimes won't start when it is warm.I have to wait about an hour or so for the motor to cool down before the engine will restart. Run great after
    Restarting.
  2. #2 Re: wont start when warm
    Any codes? What motor
  3. #3 Re: wont start when warm
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    my car does the same, only on the really hot days.. my mechanic says its the cam shaft postioning sensor starting to fail, with all the heat it starts to lose contact then when engine cools it has contact and starts right up..
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  4. #4 Re: wont start when warm
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    Try cleaning the throttle body. My 04 used to only start when it was cold out and I would need to push the gas to get it to start if it was warm or the engine was warm. While you are cleaning the throttle body you should also clean the MAF since it is right there
  5. #5 Re: wont start when warm
    04+ is completely different than 97-03
  6. #6 Re: wont start when warm
    Dec 2008
    Lawndale, CA
    I had a similar thing occur on my mom's 96 regal with an L36. It would not start at times after the car had been running for awhile. Turned out to be the fuel pressure regulator. Once I swapped that, the car started and ran fine even after it ran for awhile.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. diffucult warm start
    By Sowhatsup2000 in forum General Tech Discussion
    Last Post: 07-03-2010, 07:31 PM
  5. Rough on warm start
    By hacket in forum General Tech Discussion
    Last Post: 03-22-2009, 12:01 PM
