Thread: Gettin too hot
Results 1 to 11 of 11
  1. #1 Gettin too hot
    Jun 2013
    Fl
    My 04 Grand Prix has started to run hotter than it should, up to 240...would probably go higher if I let it. Have replaced coolant elbows, t stat and bled the system and replaced radiator cap. Did a pressure check on the radiator and it lost one pound in 20 minutes. It will cool down immensely if I run the ac on hot. Any ideas?
  2. #2 Re: Gettin too hot
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    water pump fins gone?
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Gettin too hot
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    Is the radiator just all gunked up?
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  4. #4 Re: Gettin too hot
    do the fans come on when the ac is off? once the engine get hot?
    and check the front of the radiator, really the a/c condenser, they can get clogged up with dirt or bugs. degreaser and a hose from inside to the outside will help clean the dirt and bugs out if you see any of that.
  5. #5 Re: Gettin too hot
    Jun 2013
    Fl
    I'll be checking the water pump and radiator today. Scotty, the fans come on without ac at about 219, they cool it slightly but not a lot.
  6. #6 Re: Gettin too hot
    GT Level Member penright's Avatar
    Mar 2013
    United States
    Does it run hot only while stopped? Does it cool ok when moving?
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  7. #7 Re: Gettin too hot
    Jun 2013
    Fl
    penright, it would stay cool when the weather was cool but when it's hot it wouldn't cool all the way down.
    We figured it out though, when I went to pull it into the garage today, it seemed like it was running only 5 cylinders so we pressure checked the radiator again, wasn't holding at all, so we broke it down and started pressure checking the cylinders. One of the cylinders in the back was only hitting half the pressure of the others. Started tearing it down and on the way we find a busted LIM gasket and of course the head gasket too.
    Lesson learned: keep your coolant fresh and flushed. It had built up in the water ports and completely clogged two, probably caused the car to start running hotter in the first place.
  8. #8 Re: Gettin too hot
    Pretty hard to blow a headgaskets, but getting it overheated more than a few times and it bound to happen.
  9. #9 Re: Gettin too hot
    Jun 2013
    Fl
    It's been running hotter than normal for a while now...my mechanic(Dad) kept ignoring it so now he's gotta pull it all apart
  10. #10 Re: Gettin too hot
    those clogged cooling ports where the lim meets the head will make it run hot for sure.
    you may want to take that head in to a shop to be gone over since its off. or both of them.
    or just find a top swap and put that back on. insert evil laugh here__________ lol
  11. #11 Re: Gettin too hot
    Jun 2013
    Fl
    I dropped both heads off at the shop this morning to get checked out
  1. Finally gettin a gtp
    By silverPGP in forum Off Topic Discussion
    Last Post: 06-08-2010, 11:31 AM
  2. Gettin my car on a dyno
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 04-04-2010, 01:08 AM
  3. gtp's gettin BLACKED OUT
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 02-10-2009, 02:01 PM
  4. Im gettin hooked up!
    Last Post: 09-23-2008, 11:04 PM
  5. i think im gettin it finally....
    By whitcomb in forum Visual/Body Modifications
    Last Post: 06-11-2008, 08:00 PM
