Thread: L36 Overheating
Results 1 to 6 of 6
  1. #1 L36 Overheating
    SE Level Member overdose666's Avatar
    Oct 2011
    Houston, TX
    2003 Monte SS with 140k
    Hit the danger zone on the temp gauge today, got it home and checked it out. Definitely blew the t-stat gasket. Bout 2 weeks ago it overheated on me, all the gaskets were fine but i had boiled off most of my coolant, oil was clean and i tore down to the LIM and didnt see any stray coolant, at that time i replaced the T-stat and flushed the coolant. For the past few months I've had issues with the coolant boiling off, even after a 10 min drive to taco bell, when i stop i can hear the coolant in the over flow boiling.
    In spring of 2010 I replaced the water pump, LIM gasket, t-stat, and radiator fans. All of which are holding up fine. I know theres a bigger issue causing this but I cant figure it out.
    Any suggestions?
  2. #2 Re: L36 Overheating
    Upper intake manifold cracked?
  3. #3 Re: L36 Overheating
    Jan 2012
    FT Campbell, KY
    water pump? correct chemistry of the coolant? purged the coolant system at the thermostat housing? enough coolant in the system?
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  4. #4 Re: L36 Overheating
    HUDSON
    The radiator cap is directly responsible at keeping pressure raising the boiling point. You have not stated that you inspected or replaced it.
  5. #5 Re: L36 Overheating
    Oct 2011
    Houston, TX
    Quote Originally Posted by QUICKSILVER462 View Post
    That I havent and ti completely slipped my mind, that will probably be the next thing i try.
    UIM is solid, with a new gasket and no visible leaks. When the coolant was last touched i did a thorough flush, and got it topped off. I'm not sure of the warranty the new water pump came with, but the gasket is fine and its not making any odd noises so I'll assume its fine for now, although i may come back to it.
  6. #6 Re: L36 Overheating
    Oct 2011
    Houston, TX
    Radiator cap was bad, I feel stupid lol. Atleast it was a cheap fix.
  1. overheating
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 12-18-2012, 12:22 AM
  2. Car overheating
    By Wsmccoy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2012, 07:48 PM
  3. Overheating
    By Mr Darrell in forum General Tech Discussion
    Last Post: 06-13-2011, 10:50 AM
  4. overheating
    By mcdriver in forum General Tech Discussion
    Last Post: 01-24-2011, 01:24 PM
  5. **overheating**
    By tmackster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 04:18 PM
