Thread: What now???
Page 1 of 3 123 LastLast
Results 1 to 20 of 59
  1. #1 What now???
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Yesterday my car start skipping like it was out of gas,didnt seem to go unless floored and still not much,but never failed to start,about 30 mins later crunk and drove a few feet,never hesitated again,it's a 00 gp gtp,my gas hand was going up and down,my fuel pump is still working I believe,who ever before me replaced the to cool pack cause it has that yellow junkyard writing on it,it has a quarter tank in it,I called the tow truck to come get it and take it home,got home drove it and now nothing,what can it be??
  2. #2 Re: What now???
    Jul 2010
    Posted in wrong section my bad
  3. #3 Re: What now???
    What's the to cool pack?
  4. #4 Re: What now???
    Jul 2010
    Meant coil pack
  5. #5 Re: What now???
    Jan 2013
    Tn
    Rpms reading 0?
  6. #6 Re: What now???
    Any codes?
  7. #7 Re: What now???
    Jul 2010
    My rpm hand has never worked,I have no way to see if its throwing codes cause I live 15 miles or so from autozone and I'm afraid to get out in it,it hasn't hesitated again,it just started skipping like it was running outta gas,it died crunk it again,drove it again and died again but had a quarter tank in it,I drive is exactly 73 miles that day and the day before combined,it was 90 outside but don't think heat was a factor,idk else what to check for or how to
  8. #8 Re: What now???
    is the check engine light on? if not, theres no code to read most of the time.
    could be a crank sensor. they like to make the car stall, then it will restart, or not restart for hours, days or weeks, they will of a sudden decide to work again. crank sensor rarely sets the cel light off.
  9. #9 Re: What now???
    Sounds like crank sensor to me.
  10. #10 Re: What now???
    Jul 2010
    UPDATE-I took my map sensor off my 00 gtp and put the one 0ff the 03 se and it seemed to run better,i had ful boost and it was more responsive like before I had to floor it going down the road to get full boost now I can bearly push the gas and it does good but then it wouldn't start,i unplgged it and it seemed to start but not to sure if it caused that but I put the old one back in so we can drive the se and now hardly any boost,it didn't seem to start with the sensor off the 3.1,they have the same numbers and are identical but wouldn't start,not sure if it was causing the starting but know its dirty or bad because the boost,i drove the gtp a mile and drove good with 3.1 sensor and boost was the best its ever been,my dad said the coil pack may be getting hot,is that possible???
  11. #11 Re: What now???
    Jul 2010
    ive also heard the crank sensor can cause the rpm hand not to work,whats the signs of a bad one,can it cause boost problems??
  12. #12 Re: What now???
    crank sensor symptoms are right before it stalls the tach drops to zero, then the car stalls.
    some times they fire right back up, sometimes they dont.
  13. #13 Re: What now???
    Jul 2010
    my rpm hand dosent work and service engine light is on and always have
  14. #14 Re: What now???
    whats the code? have you had it scanned yet?
    its free at most parts stores.
  15. #15 Re: What now???
    Jul 2010
    haven't drove it there yet because im afraid it will go crazy and I don't have the extra money to have my car towed home, think I only get 1 tow for free per month per vehicle
  16. #16 Re: What now???
    short of having a scanner come to you, you'll have to get the car there.
    whenever the cel light comes on your car is asking for help. they should be checked asap.
  17. #17 Re: What now???
    Jul 2010
    I been aiming to buy a obd 2 usb cable or scanner,would this work good enough Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive
  18. #18 Re: What now???
    Jul 2010
    we drove our 94 gand prix for 9 years with the light on,thought it was a grand prix thing,our 03 se one is on to
  19. #19 Re: What now???
    both of your cars are asking for help, any time the lights on your engines not running up to its full potential. its not a GP thing, a sensor went bad.
  20. #20 Re: What now???
    Jul 2010
