Thread: Not starting
Results 1 to 19 of 19
  1. #1 Not starting
    Jun 2012
    Golden Eagle, IL
    ok so for the last few days the car has been slow to crank over but would start, last night I got in it and it did nothing. I put the battery charger on it last night, tried again this morning, and still nothing. All lights and radio are working but it won't start. I need help
  2. #2 Re: Not starting
    how old is your battery? id think its dead. and wont take a charge any more.
  3. #3 Re: Not starting
    I'd check the battery connections..
    Look at your battery.. do the sides look puffy? Puffy is a classic symptom that it's been heated etc a bunch and is likely near or at the end of it's life.
  4. #4 Re: Not starting
    Jun 2012
    Golden Eagle, IL
    how could the battery be dead if, all the lights are still working?
  5. #5 Re: Not starting
    not enough volts left in it. test it. also check all the cables like Bill said.
  6. #6 Re: Not starting
    Jun 2012
    Golden Eagle, IL
    I pulled the multimeter out and it said 12.6 volts, the cables look great, they are tight and no corrosion, I tried jumping it with the battery booster and it still doesn't even turn over, so im thinking starter, btw the battery is 2 and half year old
  7. #7 Re: Not starting
    Actually..it would be enough volts, not enough amps.
    Volts are horsepower, amps are torque. A little Honda can drive on a flat surface w/o losing speed, give it a hill and it doesn't have any torque to maintain the speed uphill.
  8. #8 Re: Not starting
    hit the starter with a hammer, if it cranks after a few hits, the started is bad.
    you getting a click when you turn the key to start?
  9. #9 Re: Not starting
    Jun 2012
    Golden Eagle, IL
    amps are good around 850, I get nothing when I try to start it, no click
  10. #10 Re: Not starting
    the dash cluster go black when you turn the key? like its supposed to?
    did you hit the starter with a hammer yet?
    you check the grounds on the trans bell housing? there should be 3 wires there, 1 fat black cable, (the bat neg), and 2 smaller wires with a loop each. make sure they are on there, and tight.
  11. #11 Re: Not starting
    Trans is reading as P or N on cluster, right?
  12. #12 Re: Not starting
    Jun 2012
    Golden Eagle, IL
    haha yea trans is in park and I have tried it in all position just to make sure it wasn't the linkage, hammer didn't help and all wires are tight
  13. #13 Re: Not starting
    Typically you don't get a slow crank from a dying starter. Usually that's a battery issue. However since you did the tests and say it's good, hmmm
    Try using a screwdriver to jump power from the positive terminal to the soleniod wire. Let's rule out ign switch and all that crap. You get bonus points if you put the key in teh run position before going under. That way..you might have a started car.
  14. #14 Re: Not starting
    you can try to jump the starter also, take a screw driver, and bridge the large power cable on the starter to the the smaller terminal, this should make the engine crank, if it cranks, you got a ignition harness problem maybe.
    turn the key to run, sparks will fly when you jump the starter, so dont freak out.
  15. #15 Re: Not starting
    Jun 2012
    Golden Eagle, IL
    its alive
  16. #16 Re: Not starting
    Jun 2012
    Golden Eagle, IL
    it still has a really slow crank, and it doesn't always want to start with the key
  17. #17 Re: Not starting
    Jun 2012
    Golden Eagle, IL
    now I have nothing again, I can't even get it to turn over shorting the starter
  18. #18 Re: Not starting
    what did you do to get it to crank? lest us with what you've done and checked.
  19. #19 Re: Not starting
    Yeah...
    It's alive.. Yippeeeee was my feeling
    Still slow.. hmm maybe pull it and test it.. my though
    Nothing... darn dude!
    If you get zippo..then I'm thinking power supply, which leads me to battery. You can test a battery as good the way we told you and it can still be bad. Maybe it's time to haul the starter and battery to the parts store for testing.
  1. not starting
    By v8wannabe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2012, 02:54 AM
  2. Need Help Please with not starting
    By flaspeeder in forum General Tech Discussion
    Last Post: 10-24-2011, 04:13 PM
  3. starting to mod
    By LeThAlREMiX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 08:38 AM
  4. Just Starting!
    By fpgt17 in forum Introductions/Noob Questions
    Last Post: 01-17-2011, 01:01 PM
  5. Starting to Mod
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 05:04 AM
