I recently replaced the power steering pump that was bad on my 2005 N/A. While was at it I replaced both pressure line and return line.
When assembling the lines to the pump and rack I used thread sealant to make sure there is a good seal.
It seems that steering fluid is running down the pressure line from the connection to the pump. It's very little but drips are shown on the ground.
What can I do here? The lines were not a perfect alignment when installed so I had to manipulate them a little but not damaging. I actually attached the pressure line to the pump unbolted to engine and then attached the pump to engine.
