Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 4 of 22 FirstFirst ... 2345614 ... LastLast
Results 61 to 80 of 438
  1. #61 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member GaBear's Avatar
    Dec 2008
    Gainesville, Georgia, United States
    Quote Originally Posted by x1lightning View Post
    well i made some calls to the local salvage outfiits today, and i would be looking at over 2k for a motor and tranny, so i think i am back to selling this SE and just buying a GTP...
    Try this Link for Used parts
    Car-Part.com--Used Auto Parts Market
    I Found a 99 S/C Motor An trans for $1200. Just wish I had the money to go and get them right now.
    BEAR
    97 Grand Prix GT: 2D/ 3.8 Liter/ AutoMatic / Cool Air Intake/ Full Magna Flow Exhaust
    More to come later
  2. #62 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jul 2008
    Germantown, Maryland
    well there are advantages to the top swap such as higher compression
  3. #63 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member pontiackid's Avatar
    KCMO
    Ok... when I took my UIM of my 2000 for the topend swap there was a LARGE dia hose coming out of it. I think it is called Evac. According to some GTP Diagrams this goes to the 3rd (closest to the firewall) vacume tree. Is there an adaptor or part I need to connect the to? Or can some one who has pics of the top swap post them.
    And one tree goes to the bypass and the other to nothing or "atmosphere" correct?
    Thanks
    -KT
  4. #64 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The large diameter hose is for your brake booster. You can get a brake booster hose from an L67, or I think you can just make it work.
    The middle of the tree is for the vac line for the HVAC system, it's the smaller hose that's connected right next to that big one mentioned earlier.
    2001 Buick Regal LS - Almost Stock
  5. #65 Re: Top Swap Info and Faqs, Also lots of 3800 Info
  6. #66 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    KCMO
    How rough should the motor be when you first start it before it adapts and gets use to boost?
  7. #67 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Barksdale AFB, LA
    Quote Originally Posted by pontiackid View Post
    You need a new tune. End of story. It can't "adapt" enough if you try to use the same PCM. The best way to do it is start with a L67 file and change it to work with your trans. Then tune fueling and spark as needed to keep it from blowing up.
    Mine chattered a little bit as the lifters got pumped up, but even the first start on mine and ever since was perfectly smooth. Runs as good as it did when it rolled off the assembly line if not better.
    2009 Subaru Impreza WRX STI
  8. #68 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    KCMO
    I know I need a tune. I guess my problem is in the MAF... (idles when not pluged in and will die when pluged in) I'm not showing any boost (even when reved up) on the DIC and I am showing 15ish VAC on my mechanical gauge. Couldn't find any Vac. leaks either...
  9. #69 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Barksdale AFB, LA
    Did you use a L67 PCM and MAP sensor?
  10. #70 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    KCMO
    Yes, I am using a GTP file and a 67 MAP.
    My digital DIC is showing no boost periord. Though my mechanical Autometer gauge is holding at 15psi VAC and after I reved up, I am hitting 20-22 VAC.
    We hooked it up to an HPtuner and my MAF is still giving me a reading but, is way off. When it is connected/plugged back in it will kill the car.
    About the MAF it is my old 2000 one, just put it on a 67 TB.
  11. #71 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Barksdale AFB, LA
    You probably need a new MAF. If you're getting no boost I'd look to make sure the BBV is operating properly and not stuck open.
  12. #72 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    New Hampshire
    does any one have pictures of the location of the series 3 supercharged motor???
  13. #73 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Barksdale AFB, LA
    Quote Originally Posted by imjustanobody34 View Post
    I'm pretty sure the motor is in the engine bay...
  14. #74 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    el paso
    can i swap my n/a for a supercharged?
  15. #75 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    KCMO
    Yes... read page 1
  16. #76 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Hoffman/Schaumburg, IL
    Quote Originally Posted by Sabrewings View Post
  17. #77 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member l3enner's Avatar
    Niagara Region, Ontario, Canada
    So I've been reading up on this, and I'm very interested in doing it, but has anything thrown out an approx/avg cost involved in doing this? I have an 04 grand prix gt that I'd love to do a top swap on, just looking for a little better idea of the money involved before commiting to something... as all mods are based on budgets. haha
    Bruce Benner - Niagara Region, Ontario, Canada
    2004 Grand Prix GT2 - Tinted Windows,Tail lights, 20" Velocity VW166 rims...
  18. #78 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member skidoojames151's Avatar
    seattle
    contact ed morad parts..google it...and email him asking for his top swap kit and he will hook you up
  19. #79 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Quote Originally Posted by gonzo915gp View Post
    Did you really post that in the Top Swap thread?
    Jesus, some people's kids.
    Quote Originally Posted by skidoojames151 View Post
    Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    Just tell Ed that your part of the national grand prix forum and he'll set you straight.
  20. #80 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Michigan
    Ed quoted me $1100 for all the hard parts...plus shipping.
    The labor would be murder if you take it to a shop though.
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
