Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 20 of 22 FirstFirst ... 101819202122 LastLast
Results 381 to 400 of 437
  1. #381 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Dec 2012
    Where 4T65E's were born
    Honest question. What's the pros and cons on topswap vs. complete L67 swap? I know the flex plates will have to be switched, maybe a few other things. I would rather find a used $400 L67 in the area than spend $1200 on a top swap.
    Sold.
  2. #382 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    Basically the only advantage of a topswap is it'll have 5% more power due to the N/A block having higher compression. This does however make a topswap more vulnerable to KR without the proper supporting mods.
    2000 GT Mods: HAI, 10.5mm wires, rebuilt 60k motor, ZZP stainless headers, magnaflow mufflers, fresh paint job,L-67 top swap, Ported SC...
  3. #383 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Florida
    Also in addition to the compression increase, most retain the better gearing from the NA trans.
  4. #384 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    do a whole motor swap and do all the work to it outside of the car (do a cam, seriously).
  5. #385 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    Will higher octane help out with KR? Also... where would the MAP sensor be on an L32, since this thread seems to be supporting L67s more, and will the 2-bar MAP for an L32-to-L26 top swap need the different connector too? Or does ZZP offer a bootstrap adapter pigtail now? Sorry in advance for what seems like tired old questions (but like I said I didn't see any MAP Q's for 04+)!
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  6. #386 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mercer, Pa
    I'll answer first question about octane! YES, higher octane gives lower KR. E85 is like 105 octane!
  7. #387 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member Thethudelh's Avatar
    Apr 2014
    Sandy Ridge,NC
    I need to replace my motor in a 00 GTP.Dropped a rod and am wanting to use a 97-03 N/A block for this heart transplant. If I keep all things the same save for the block and internals, is there anything I would need to do for tuning due to the compression ratio difference? Also, I know this is off topic a bit but I want to install headers. Will I need to change the down pipe to get rid of the u bend? I know these are probably newbie questions but i am not a mechanic, i just love messing with my car lol. Thanks in advance.
  8. #388 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Florida
    yes there will be extra tuning needed. if you are currently running just the stock pulley and adding headers you will still need to add rockers or another flow mod to safely run with the added compression. tuning will be a must. just for comparison, i am running a ported tb and blower, ported heades with high flow valves, headers, and 2.5" highflow exhaust. I had to do a good amount of tuning to get it all dialed in and make it a solid daily driver.
    oh and the headers have their own downpipe. it will replace the secion that has the ubend
  9. #389 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Jan 2009
    Tallahassee, FL
    At the very least you will need to run a larger pulley and plog/DP if you do nothing else, the tune is a must no matter what. I'm running L32 heads, plog/dp, rockers, a ported blower, with a stock pulley. I've got headers that I still need to throw on and a 3.6 pulley.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #390 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2015
    Ok I'm am gonna do a top swap for my base 3.8 2005 grand prix. Wat is the 1st thing that I should start with?. I reviewed ur list on what I need but still jus wanna clarify the steps cuz mine is a 2005 base
  11. #391 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2012
    NC
    Quote Originally Posted by demigodz1984 View Post
    It's the same stuff.
  12. #392 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2015
    Ok thanks man
  13. #393 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Kemmerer, Wyoming
    heads ported by chris hinson, aka orangeL67,
  14. #394 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2015
    Ok so now that I think bout it I got 165000 miles on my L26 NA engine I should jus put a whole new engine in right?. I should jus rebuild a L32 it would be a wiser move u think
  15. #395 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2015
    Cuz I'm gonna go and start grabbing parts
  16. #396 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    165k is nothing, don't try to rebuild, it wonk work out unless you drop a lot of cash at a machine shop. Seriously, 165k miles is not a lot for these engines.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  17. #397 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2015
    Thanks good to kno wasn't sure how they fit with mileage
  18. #398 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2015
    Still tho if I'm gonna do this car over I want the engine bay looking clean and badass
  19. #399 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Mar 2015
    Jus need a good understanding on the swap for the engine I got cuz I see alot of swaps but not the one I got so I'm kinda lost still reading alot tho
  20. #400 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Apr 2015
    Columbus, OH
    Get the top swap parts off an L32. Only difference I know of is you have a drive by wire TB, as does the L32. Everything else in the swap will be the same.
    Top Swapped 01 Imp
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
