Thread: Top Swap Info and Faqs, Also lots of 3800 Info
Page 6 of 22 FirstFirst ... 4567816 ... LastLast
Results 101 to 120 of 438
  1. #101 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    you need a lot more than just the blower. did you read any of the threads that you were supposed to search before you posted?
  2. #102 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Wausau, WI
    I think he meant because it was a gen III blower would it work on a series III 3800....
  3. #103 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member Kluke's Avatar
    Michigan
    Yes I read everything I could find I know I will need more than the blower. I wasn't sure if the gen 3 blower will fit on the 04 and newer gp's
  4. #104 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    it will with a TB adapter. you need to keep the drive by wire throttle body. no one sells one, but it cant be too hard to make by hand.
  5. #105 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    I wouldn't use a GenIII. Even a ported one doesn't flow as well as the GenV. If you're going to do it, do it right the first time and spend the extra cash
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  6. #106 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Michigan
    alright thanks for the advice
  7. #107 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member Cougar281's Avatar
    Nov 2009
    St Louis, MO
    I do have one question about this swap...
    30 - Run a vacuum line to the fuel pressure regulator and the MAP. The fuel pressure regulator needs to see boost in order to operate correctly. Go ahead and attach the Boost Bypass Valve to the supercharger. It's held on with a bracket and two bolts. Run a vac line from the tree on the supercharger to the top nipple on the BBV. The bottom one needs to see ATMOSPHERE, because our L36 PCM's cannot control the BBV.
    Why is this? Does the L67 PCM control the BBV? If so, the L36 PCM should be able to control it with the right tune (or swapping in the L67 PCM if you can't tune it). If the harness is missing wires, add them and have it done right...
  8. #108 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Banned - Busted For Scamming
    Feb 2009
    You wont wanna use it anyways. Once it starts messing up it will give you nothing but problems.
  9. #109 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Nov 2009
    St Louis, MO
    One other thing; The article says the timing is off 1* from the factory on the N/A motors. This doesn't need to be "fixed"?
  10. #110 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    no, just run the timing straight up at 0 where it should be.
  11. #111 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Nov 2009
    St Louis, MO
    So if the N/A motor is 1* off, but it should be run at 0, then the cam does need to be re-timed?
  12. #112 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    where does it say that the n/a motor is a degree off? also, if you time it at zero per the marks on the gears then it will be at zero. its not possible for it to be a degree off if you put everything on correctly.
  13. #113 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Nov 2009
    St Louis, MO
    In the very first post....
    Quote Originally Posted by 02BlueGT View Post
    The NA motors have the cam timing off one degree from the factory
  14. #114 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    SE Level Member ceelo's Avatar
    atlanta
    most important step is to find the updated lower intake gasket ive read it has aluminum incorporated into it however the only one i have been able to locate for 04 gtp with sc engine is the felpro FEL-PRO Part # MS959771 {Set}
    2nd Design; w/Rubber-plastic end seals w/Locating pins; Lower set but was told this is prone to failure also so where to buy and what brand cause even the dealer service dept seems to be unaware of the aluminum upgraded gasket also any info on why when replacing lim gasket one would replace lifters as in the video i have small leak and no water in oil say this cause do not see milky gunk on oil cap dipsick
  15. #115 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Wausau, WI
    you dont have to replace the lifters when doing the changeover, it was stated in the video that it was only done because in that car the lifters were no longer working correctly at that time. If your lifters are fine, don't touch them. Also, use the felpro 04 and newer LIM gaskets for best results. This should have been posted in the video thread or start a new one. There are many threads about the LIM gasket replacement. Use the search button first please.
  16. #116 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    GT Level Member black98gt's Avatar
    Rochester NY
    how did you guys connect your fuel lines from the L36 up to the L67? I see that theyre differnet connectors on the ends of the fuel lines from each engine.
  17. #117 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Pulled this out of the top swap FAQ
    28 -Place your new L67/new aftermarket injectors into the heads with new o-rings. Gas leaks can occur due to a cracked o-ring. Place your new L67/new aftermarket fuel rail onto the injectors. Transfer the injector clips from the old rail onto the new one. Tighten down the rail to the 4 studs coming out of the LIM. Attach the fuel line and fuel return to the new rail. Re-attach all the injector harness plugs onto the marked injector.
    http://www.grandprixforums.net/f17/t...lots-7763.html
  18. #118 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Rochester NY
    Ya I get that part, but on the fuel lines themselves going into the fuel rails, the connectors on the ends are diff. On the L36 theres a elbow on the lines and on the L67 the lines have a quick connect going into the rails.
    Its kinda hard to see on the L36, but im sure you know what I mean.
    Do you see what I mean now?
  19. #119 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    twist the heads on them so they will click into place where the l67 rails go. thats all i did and they fit fine. make sure they dont rub on the EGR or youll have a gas leak very soon.
  20. #120 Re: Top Swap Info and Faqs, Also lots of 3800 Info
    Rochester NY
    Thanks Bio, I was hoping you would reply to my question.
  1. need info on cam swap
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 09:33 AM
  2. N/A 3800 info/mods
    By 5speedcobra in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2008, 08:30 PM
  3. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  4. Newbie looking for info
    By bigjim in forum Introductions/Noob Questions
    Last Post: 03-27-2008, 11:56 PM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
