What about the l67 swap kit do I need that boost bypass valve solenoid wire
you dont, its likely not a active code in your pcm, or a na one in general.
what you could do is find a gtp pcm of the same year as your car is. its a gp na right? and use that. it might toss a code for the bbv actuator or not. my regal didnt when i took it off mine for a while.
re use your maf if the donor engine's maf is not the same part#.
only issue with the gtp pcm is your vin wont match if you have inspection. and you need to do a security learn to make it crank and fire up. key to run 3 times for 10 minutes, off each time for less then 5 seconds. but a battery charger while you do this, and dont open the doors or power anything inside. radio, windows ect. turn that all off and dont use anything.
or call zzp and tell them your set up and give em your vin#. get a 1.0 if you plan to stay stock ish.
I believe that this is what I need
It will get you going. I'd still get something to scan for knock.
Looking to buy another scan gauge but I ordered 2 zzp pcm they played me on the black Friday sale stated starting of at 62.5 total was 236 after 10%discount gp pcm had a 75 fee for l67 engine and transmission map mc was straight forward no fees but it's all gud
Will still delete the solenoid
thats a dead fuel pump, nothing shot out the sharader valve, it should hit the cars hood. id toss a tester gauge on it. to be sure.
Right on bro will look into that in the morning
Swapped out the fuel pump with a new one fuel shoots to the hood after depressurize but still same issue but car runs better can notice on acceleration with new pimp
the maf might be bad. try unplugging it then crank it. see if it fires up. might run like crap but it should fire up.
Right on I will been doing a look research and might b the iac
its also possible, but when my iac went bad it would fire up if i touched the gas pedal.
OMG- amazing ! I am not going to be doing a TOPSWAP for the record. I began reading this thread bcuz it said all kinds of info for the 3800 s/c. I couldnt stop reading--until i finished all 22 pages. This was incredible. Now i need to find a thread that actally talks about my cars problem. I'm hoping I find will a discussion that has input from the author of this thread. I'm not an engine wizard or strong enough sometimes to perform car tasks but I love learning about my car and trying to do the maintenance. Thanks again for this thread.
I just did a top swap on my grand pri 05 GT, everything is working well, but I'm using a pcm SC and I can't use the TC, so in the cluster the TC OFF light turns on, any way the light doesn't turn on? My pcm is already programmed with Hptuners
