Thread: 2006 Grand prix misfire
Results 1 to 9 of 9
  1. #1 2006 Grand prix misfire
    Mar 2013
    Michigan
    Have a 2006 gp with 3.8 series 3 125,000 miles and i get a p303 code when i get the rpms up to 5000 and it never misfires untill i hit 5000. i have replaced the wires, coils, spark plugs, and switched the injectors around nothing changed it the light still flashes when i get to 5000 rpms also today when i came to stop and went to take off it got a p300 code. any help thanks.
  2. #2 Re: 2006 Grand prix misfire
    Feb 2013
    Minnesota
    Why you running it with the Rpms so high?
  3. #3 Re: 2006 Grand prix misfire
    Mar 2013
    Michigan
    I dont drive it like that im just saying thats the only time it misses it happend when i was passing a car and thats when it threw a code
  4. #4 Re: 2006 Grand prix misfire
    What plugs?
    It may be the ICM causing this issue aswell.
  5. #5 Re: 2006 Grand prix misfire
    Feb 2013
    Minnesota
    Good. I was gonna say I wouldn't run that hard. Can't be good for it. Maybe try cleaning the Mass Airflow wire connections. My old 99 gp se 3.1 had a aweful idle and check engine light would come on. Doing research I pulled the connection the the Mass Airflow and it smoothed out and the light went off. I then cleaned the connections up good with WD-40 and it ran perfect again.
  6. #6 Re: 2006 Grand prix misfire
    Mar 2013
    Michigan
    Could that cause just one cylinder to missfire?
  7. #7 Re: 2006 Grand prix misfire
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Not likely
  8. #8 Re: 2006 Grand prix misfire
    Mar 2013
    Michigan
    So what could cause just cylinder 3 to missfire?
  9. #9 Re: 2006 Grand prix misfire
    chipped piston, or a clogged cat. check the spark plug for damage, the old plugs, were they still all there? or was one smashed or missing the bottom part?
    flashing cel means misfires, or clogged cat.
  1. Help! 2004 Grand Prix GT misfire
    By Scott Gerhart in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2015, 02:46 PM
  2. grand prix misfire
    By patrick 721 in forum Introductions/Noob Questions
    Last Post: 11-28-2012, 02:34 PM
  3. 2006 Grand Prix
    By chad mick in forum Introductions/Noob Questions
    Last Post: 11-25-2012, 04:34 PM
  4. p301 misfire '02 Grand Prix SE
    By sicayan in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-28-2010, 08:00 PM
  5. 96 grand prix misfire
    By krcorbett in forum General Tech Discussion
    Last Post: 10-13-2009, 03:56 PM
