Thread: Antifreeze color mix??
Results 1 to 9 of 9
  1. #1 Antifreeze color mix??
    Feb 2013
    Minnesota
    I noticed my antifreeze level was low. I added about 1/5 gallon of green anti freeze. Curious I then opened the radiator cap and noticed the coolent was orange. Is it bad to mix these?!
  2. #2 Re: Antifreeze color mix??
    Banned
    Sioux Falls, SD
    YES not a good idea they gel up, flush it ASAP and put either dex or green. id say green
  3. #3 Re: Antifreeze color mix??
    Feb 2013
    Minnesota
    Do you think it's fine tho? I didn't add much of the green stuff, when I realized it was supposed to be orange I got a bottle of it the orange stuff and topped it off with that. I don't think I added more then 20oz of the green stuff
  4. #4 Re: Antifreeze color mix??
    Dec 2008
    Lawndale, CA
    Did you get the green one that can mix with all types of coolant or just standard green? If it's the one that mixes with all coolants i think you are safe.
  5. #5 Re: Antifreeze color mix??
    Feb 2013
    Minnesota
    I don't think it mixes. It's just Durex 50/50
  6. #6 Re: Antifreeze color mix??
    Pennsylvania, USA
    The "mix with all" is like a neon green/yellow, the one that will call it up is just a pure green.
  7. #7 Re: Antifreeze color mix??
    Jul 2012
    Chicago
    Get a flush anyways. Peace of mind.
    -Carl
  8. #8 Re: Antifreeze color mix??
    Feb 2013
    Minnesota
    I'm a guy. I don't know the difference between neon green/yellow, and green. I see colors as: light, regular as dark
  9. #9 Re: Antifreeze color mix??
    GT Level Member GP Guy 07's Avatar
    Feb 2013
    Elgin
    Quote Originally Posted by The Guz View Post
    Yes it is.I've been using that with no problems.Just have to read the label to see mixes with all coolant.
    07 GP black on black,SPO spoiler,grills,hai,aftermarket rims,Led tails,drilled+slotted rotors
  1. oil in antifreeze
    By lorello in forum General Grand Prix Discussion
    Last Post: 06-19-2012, 09:55 AM
  2. Oil In Antifreeze
    By zackp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2012, 01:34 AM
  3. GTP Overlay color on my white GTP- which color
    By GTLGDP in forum Visual/Body Modifications
    Last Post: 01-13-2012, 11:53 PM
  4. ideas for accent color and color scheme under the hood
    By BoostnBlackGTP in forum Visual/Body Modifications
    Last Post: 03-31-2011, 04:53 PM
  5. Idk, antifreeze?
    By Tha Ghost in forum General Tech Discussion
    Last Post: 01-30-2011, 09:49 PM
