Thread: How many degrees of KR do you get?
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 91
  1. #1 How many degrees of KR do you get?
    May 2012
    Albuquerque, NM
    Just curious what my NA friends are getting when it comes to KR? I generally get about 5* at 50%'ish throttle, up to 9* at WOT. I have headers, upgraded alt cable, voltage booster.
  2. #2 Re: How many degrees of KR do you get?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    n/a 3800 with headers shouldn't be getting much/any kr, with my mods I was tuned downed to 0 kr.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #3 Re: How many degrees of KR do you get?
    I can see 5* or 0*. Haven't really tuned it yet though. It's like a personal challenge to not tune it.
    PS, keep in mind I have higher loads than you do. I'm running 2.93 gearing. A GP NA should be 3.29
  4. #4 Re: How many degrees of KR do you get?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I believe the highest I saw was 6* but nothing more than that
  5. #5 Re: How many degrees of KR do you get?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    7.7*
    Right after a dead spot in the stock tune where my timing like to drop to 0.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  6. #6 Re: How many degrees of KR do you get?
    Apr 2011
    Tally, FL
    i've seen up to 16 when i was stock and then down to 8 with a ported lim and then 5 with headers if you'll run 93 it probably drop to like 2-3
  7. #7 Re: How many degrees of KR do you get?
    May 2012
    Albuquerque, NM
    I only run 91 (highest avail) but I have not started my tune yet. I am going to buy a spare before I tune anymore. I had one brick and it was a PITA to get one in my town. Now a spare is a must for me. I'm sure it's due to the stock tune but I hate having any at all.
    So, it's a little high but on the high end of par for stock tune?
  8. #8 Re: How many degrees of KR do you get?
    My wifes bonneville shows about 8* almost always when trying to get on it.
  9. #9 Re: How many degrees of KR do you get?
    Newnan, GA
    I noticed no difference running 93 compared to 87.
  10. #10 Re: How many degrees of KR do you get?
    St Thomas Ontario
    you wont unless your tuned for it,or have high kr.. and being n/a its not a huge difference.
  11. #11 Re: How many degrees of KR do you get?
    Newnan, GA
    At what point is kr generally considered "high" ?
  12. #12 Re: How many degrees of KR do you get?
    I didn't like seeing more than 2* on my gtp.
  13. #13 Re: How many degrees of KR do you get?
    Jul 2012
    Chicago
    I've seen up to 6 running 87. Running 93 it stays under 5. Still dog slow no matter how you cut it.
    -Carl
  14. #14 Re: How many degrees of KR do you get?
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    May I ask a Newbie-ish question??? What is "KR"???
    2002 GT Red, Stock, Work In Progress..........
  15. #15 Re: How many degrees of KR do you get?
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    Quote Originally Posted by 02GPinNY View Post
    KR is an abbreviation for "Knock Retard". The PCM is retarding ignition timing because it has sensed knocking.
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  16. #16 Re: How many degrees of KR do you get?
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by EJOUIE View Post
    Above 0
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  17. #17 Re: How many degrees of KR do you get?
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by TeeWX View Post
    Thanks! Learn something new everyday!
  18. #18 Re: How many degrees of KR do you get?
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    http://www.grandprixforums.net/what-...here-1507.html
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  19. #19 Re: How many degrees of KR do you get?
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Stock 2004 GT2 with 231K. I get Zero KR.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  20. #20 Re: How many degrees of KR do you get?
    SE Level Member skylar44's Avatar
    Jul 2012
    Toronto
    5-6* at WOT, anywhere between 2-13* slighter accelerating (13 was uphill) on 87
  1. My new oil cap is 90 degrees out. :(
    By Kilroy in forum Visual/Body Modifications
    Last Post: 03-28-2013, 07:09 AM
  2. ~7 degrees of KR on 3.5" pulley, please Advise
    By Impala131 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2012, 05:49 PM
  3. Suddenly getting 10 degrees of KR
    By buickman104 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2012, 10:36 PM
  4. Hello from Texas its 73 degrees here
    By Mjr Minor in forum Introductions/Noob Questions
    Last Post: 01-01-2009, 09:24 PM
  5. Ihave 4 degrees of kr
    By ryangtp89 in forum General Tech Discussion
    Last Post: 03-16-2008, 12:34 PM
