Thread: 2006 GP Coolant leak help!
Results 1 to 6 of 6
  1. #1 2006 GP Coolant leak help!
    SE Level Member LogicGTP's Avatar
    Oct 2008
    Fremont, CA
    Just on the weekend the car started to leak coolant after a trip to LA. I notice it was wet on top of the water pump but I couldn't see from where it was leaking. Any ideas? water pump gasket? I'll take a picture of it in couple minutes to show you guys.
  2. #2 Re: 2006 GP Coolant leak help!
    Check the upper coolant elbow right above the water pump.
  3. #3 Re: 2006 GP Coolant leak help!
    Oct 2008
    Fremont, CA
    is that the one with the 2 O rings on each side?
    if so I have replaced that on my firebird about a trillion times :/
    YES, I took a look at the elbow and its cracked in half.
    will it be a good idea to get this ones from zzp? http://shop.zzperformance.com/store/...t-Elbows.aspx#
  4. #4 Re: 2006 GP Coolant leak help!
    St. Louis
    You can get the aluminum ones locally. I think Autozone has them, may be other places too. Should be in the "Help" section. Part # 47065HP. You can also get them from Rock Auto.
  5. #5 Re: 2006 GP Coolant leak help!
    Advance has them, ORiley's, many places stock/have them easy to purchase these days.
    Get a set..toss in a set... then you'll be all set.
  6. #6 Re: 2006 GP Coolant leak help!
    Oct 2008
    Fremont, CA
    Finally I changed both elbows ... got the aluminum ones for 10 bux !
  1. Coolant leak NEED HELP!
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-03-2013, 10:05 AM
  2. ANother coolant leak
    By srspicer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2012, 05:13 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Need help..coolant leak
    By Ktrap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 11:20 AM
  5. Coolant leak
    By john breit in forum General Tech Discussion
    Last Post: 02-12-2011, 05:12 PM
