Thread: 04 GRAND PRIX GT intake gasket
Results 1 to 20 of 25
  1. #1 04 GRAND PRIX GT intake gasket
    SE Level Member JunkBird69's Avatar
    Oct 2011
    Baltimore,MD
    Had to do the upper and lower intake on my 04, pulled everything, it looked just as good as every other one ive done.lol Question is on the lower intake there was a plastic tube that was clipped to the lower gasket, what is that for?
  2. #2 Re: 04 GRAND PRIX GT intake gasket
    Picture would help us.
  3. #3 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    Cant do anything picture wise till i get off of work
  4. #4 Re: 04 GRAND PRIX GT intake gasket
    If the plastic tube was on the belt side then that is called a coolant elbow, it needs to be repalced while doing this job.
  5. #5 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    No this was acually under the lower intake looked to possibly got to the hole for the egr or pcv probably 3/8 in diameter and clipped to the center of the lower intake gasket, I replaced the coolant elbows with the alluminium ones and ut a new tensioner on aswell
  6. #6 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    im wrong its on the upper intake gasket
  7. #7 Re: 04 GRAND PRIX GT intake gasket
    Apr 2013
    Shelby Twp., MI
    You are correct. It goes inside the plenum on top of the gasket. It has 2 clips that hold it in place.
  8. #8 Re: 04 GRAND PRIX GT intake gasket
    It's to keep the oil that does come throught he PCM from dropping at one end of the LIM.
  9. #9 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    I was not aware that oil went thru the PCM?
  10. #10 Re: 04 GRAND PRIX GT intake gasket
    Would you believe PCV? LOL
  11. #11 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    Thats more believable, I knew what you ment, so I guess I gotta put that back on then
  12. #12 Re: 04 GRAND PRIX GT intake gasket
    Mar 2013
    Cleveland
    This guy, right?
    I found mine cleaning up after doing my LIM this weekend... guess I'll put mine on too ...
  13. #13 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    That would be the one!!
  14. #14 Re: 04 GRAND PRIX GT intake gasket
    Yup.. in reality there's no downfall from it not being in the motor. I wouldn't rush to put it back if it were mine.
  15. #15 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    Just wondering where does all that oil go? I only see 1 return on the drivers side, doesnt make much sense to me
  16. #16 Re: 04 GRAND PRIX GT intake gasket
    There is no return.You know how you had to soak up the oil to see the "hidden bolts" inside the LIM? Yeah..that's what you soaked up.
  17. #17 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    thats some bs, why wouldnt they do that?
  18. #18 Re: 04 GRAND PRIX GT intake gasket
    Because..that's an intake tract...if you open that to the crankcase you cause issues.
  19. #19 Re: 04 GRAND PRIX GT intake gasket
    Oct 2011
    Baltimore,MD
    so just let oil lay in there that makes alot of sense
  20. #20 Re: 04 GRAND PRIX GT intake gasket
    Doesn't hurt anything. Didn't seem to be hurting anything when you soaked it up to pull the bolts..right?
  1. video on intake gasket replacement on 1997 grand prix gtp
    By mitcheld44 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2012, 08:45 AM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
