Thread: L67 components
Results 1 to 10 of 10
  1. #1 L67 components
    Oct 2008
    Orlando, Florida
    Are L67 Components interchangeable with the L26 engine?
  2. #2 Re: L67 components
    Barksdale AFB, LA
    Depends on which components.
    2009 Subaru Impreza WRX STI
  3. #3 Re: L67 components
    Feb 2008
    X2
    Specifically, what components are you asking about?
  4. #4 Re: L67 components
    Oct 2008
    Orlando, Florida
  5. #5 Re: L67 components
    Barksdale AFB, LA
    Quote Originally Posted by straight_upprix05 View Post
    Like we've been talking in the other thread, you would need to use a drive by wire throttle body since your car is set up for drive by wire. Drive by wire throttle bodies don't fit on the Gen III supercharger, which is in that kit.
    If you want to supercharg your car, short of swapping the whole engine for an L32, here is what you need.
    Heads (L32/L67)
    LIM (L32)
    Fuel rail (L32)
    Supercharger (L32)
    Throttle body (L32)
    Plus all the little parts that are interchangeable between the Series II and Series III engines.
  6. #6 Re: L67 components
    Feb 2008
    Quote Originally Posted by Sabrewings View Post
    I think that's what he is asking about (atleast in this thread). Besides what you got on you list there, what else is interchangeable when talking about a top swap L67 to a L32 that started out as a L26?
  7. #7 Re: L67 components
    Feb 2008
    That kit is for 03 and below Series II 3800s (L36 to L67). Judging by your name, I'm thinking that you must have an 05 and it would have a N/A Series III 3800 (L26). I would stick with those same parts as seen there but using 04 and up parts as they are Series III instead of the Series II parts listed on that link. Someone else can chime in here and probably give you more info on if there is a top swap kit available for your 05. Good luck!!!
  8. #8 Re: L67 components
    Barksdale AFB, LA
    Everything. Idler pulleys, crank pulley, coil pack bracket, etc. Those parts I listed are the only ones that changed. The only difference between Series II and Series III heads are that the Series III have slightly larger exhaust valves. Otherwise they're identical, so you can use either.
    As far as compatibility, the bottom end will work with either.
  9. #9 Re: L67 components
    Feb 2008
    Hmm really, That is interesting! Bigger valves got to work better I would think. Good to know.
  10. #10 Re: L67 components
    Barksdale AFB, LA
    Quote Originally Posted by Blown97 View Post
    It's so minuscule it doesn't even make a difference. The L26 and L36 are rated at the same HP, regardless.
