Thread: Coolant Issues
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41 Re: Coolant Issues
    Mar 2013
    Cleveland
    Everything seems to be working well, it starts a lot easier with the intake & MAF cleaned. Bleeding all the air out of the system took forever.
    Drip irrigation fittings came in handy for the flush
    This guy works great
  2. #42 Re: Coolant Issues
    Mar 2013
    Cleveland
    So it's been a few weeks now. The car is still running great, but I did notice some coolant is missing. The level in the reservoir has dropped maybe 1-1.5 inches over the past few weeks. Could this just be some air pockets working their way out over time?
  3. #43 Re: Coolant Issues
    most likely
  4. #44 Re: Coolant Issues
    forget the res, check the level in the rad when cold. first thing in the morning.
    as the engine heats up and cools, its supposed to take and put back coolant into the res tank. thats what its there for. so it should not be the same level in the tank when hot vs cold. it will move some.
  5. #45 Re: Coolant Issues
    Mar 2013
    Cleveland
    I was checking reservoir after the car had sat all day each time. Checked the rad level at the same time, that never seemed to change.
  6. #46 Re: Coolant Issues
    your good to go then.
    if the tank fills up and starts to over flow, or if it runs dry you have a problem.
  7. #47 Re: Coolant Issues
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    Did you use a designated flush agent? ....I did mine the tedious way...drained, distilled water, ran until normal op temp and drained again ....went through 10 gallons, ha...
  8. #48 Re: Coolant Issues
    Mar 2013
    Cleveland
    ok thanks. rod, I back-flushed the heater core with a garden hose, but for everything else, I used distilled like you. I only went through around 5 gallons for the actual flush part.
  1. Issues with coolant flush
    By SlyBlackDragon in forum General Tech Discussion
    Last Post: 01-23-2013, 01:09 AM
  2. coolant issues
    By ryandale in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2012, 08:35 AM
  3. Strange Coolant issues
    By Talon62 in forum General Tech Discussion
    Last Post: 06-18-2012, 07:44 AM
  4. coolant issues
    By popeyenate in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2012, 07:55 PM
  5. Coolant issues
    By blackedoutpony in forum General Grand Prix Discussion
    Last Post: 12-27-2011, 09:26 PM
