Thread: Both O2 Sensors Bad? What? I Call BS
Results 1 to 13 of 13
  1. #1 Both O2 Sensors Bad? What? I Call BS
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    2000 GT
    157,000mi
    Open cone filter thats it.
    So I have had a check engine light on for a while now because of a bad MAF sensor. I took it to Orielys after I replaced the maf because the Check engine light came back on. I just had a power steering pump line replaced and then the oil sending unit I guess. Codes that were thrown were P0102 again which is the MAF circut low input which I have reason to believe is due to the open cone filter so Im not too concerned with that. The other codes were a P0131 which is an O2 Circut Low Voltage Bank 1 Sensor 1 and a P0137 O2 Circut Low Voltage Bank 1 Sensor 2. I find it hard to believe that both would decide to crap out at the same time like this. My only thought is that the cat is the culprit?
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: Both O2 Sensors Bad? What? I Call BS
    My thought is you don't realize the maf 5volt is likely the same as the O2's. Unplug the maf, clear codes then drive and see if the O2 codes come back. If not, Maf is the issue.
  3. #3 Re: Both O2 Sensors Bad? What? I Call BS
    Apr 2012
    nova
    I looked this up yesterday, check fuse 21
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
  4. #4 Re: Both O2 Sensors Bad? What? I Call BS
    Quote Originally Posted by bigburban View Post
    I had checked fuse 21 about a month ago when I was having more MAF issues and it was fine. Probably wouldnt hurt to check again though.
  5. #5 Re: Both O2 Sensors Bad? What? I Call BS
    Didnt know that it was the same. Yesterday after I checked the codes I cleared them and drove around town perfectly fine. When I got out in the country I did a WOT run up to about 60 and it came back on. I forgot to mention that part. Thats part of the reason I thought maybe restricted flow was the issue.
  6. #6 Re: Both O2 Sensors Bad? What? I Call BS
    You went wot, the maf got cooled by the air, which meant that circuit pulled more power and poof, your craptastic maf blew the fuse.
    That's a theory.
    Cause you know that the maf reads by how much electricity it takes to heat that little wire right?
  7. #7 Re: Both O2 Sensors Bad? What? I Call BS
    Ahhhh. Yea I thought the MAF dealt with electricity but to be honest I wasnt sure how exactly that all came into play. The first MAF I got wasnt what I thought it was and so that gave me problems so I got a used one from Morad so I would think I wouldnt have any issues? I dont know. Is it because its winter and Im not using the stock air box that would cause too much cold air in? Should I just swap the intake out for stock and see if I dont have anymore issues?
  8. #8 Re: Both O2 Sensors Bad? What? I Call BS
    maybe you have some rubbed wiring.
  9. #9 Re: Both O2 Sensors Bad? What? I Call BS
    Okay. Ill poke around and see what I can find. Thanks!
  10. #10 Re: Both O2 Sensors Bad? What? I Call BS
    Pennsylvania
    It's about time to get a new cat. They last about 150k. Even if it's not the issue, it will be soon.
  11. #11 Re: Both O2 Sensors Bad? What? I Call BS
    Cat's don't clog just to clog though. I've seen stockers with 200K on them.
  12. #12 Re: Both O2 Sensors Bad? What? I Call BS
    Plus..if the voltage is low, and we are talking mV the o2 is reading, that would be lean. Cat's typically clog from a failed o2 which is super rich.
  13. #13 Re: Both O2 Sensors Bad? What? I Call BS
    Pennsylvania
    Yeah, I agree that something electrical is up, but think it's always a good idea to mind the cat.
  1. Call on me
    Last Post: 01-21-2011, 12:55 PM
  2. I'd Call 911...
    By blueguy in forum Off Topic Discussion
    Last Post: 05-28-2010, 09:41 AM
  3. The one they call...
    By spcguy88 in forum Introductions/Noob Questions
    Last Post: 02-16-2010, 11:22 PM
  4. How to call the police.
    By SlowM90 in forum Off Topic Discussion
    Last Post: 04-01-2009, 10:24 PM
