Ok, before any blows an O-ring, i have search the forum up and down and havent seen this asked yet.
ZZP sells two kits for adding the M90 to and L36.
ZZ-L36SSM90KIT ($200)
  • Garlock supercharger gasket
  • Instructions on paper and CD
  • L67 brake booster vacuum line
  • Idler pulley with custom standoff, bolt and washer
  • Throttle body gasket
  • Accessory belt (95.5" for '99+ with 3.8-4.2" pulley)
  • Autolite 103 plugs
  • Supercharger oil
  • Supercharger bolts
  • PCM reprogramming
ZZ-L36SCK ($1500+)
  • Ported Gen 3 supercharger
  • Machined lower intake
  • Modified Fuel Rails
  • 33# injectors (Stage 2 only)
  • Modular pulley system
  • Autolite 104 plugs
  • Supercharger oil
  • PCM reprogramming
  • Lower intake gaskets
Now the first question is i have not seen this pop up anywhere in the forum. $200 and a second hand blower + accessories and you have boost..(?) seems to good to be true, or why isnt everyone doing it kinda thing...
Now if this is viable to do without changing the entire top end/top swap... is it really worth it for the second kit for 1500? granted it gives you the ported blower, machined lower intake, fuel rail, 33# injectors and MPS set up.
any input guys? Thanks
