Thread: Cold air/Short ram Intake
Results 1 to 6 of 6
  1. #1 Cold air/Short ram Intake
    Feb 2013
    Houston
    i was wanting to install a basic short ram intake(cone filter with small elbow pipe) purely for the sound i did it to my Aveo and it sounds cool but i was never expecting power gains, ive done this to all my cars now that i think about it... anyway, i recently aquired a 97 Olds 88. not supercharged, and next to the air box is a small plastic screw-down cover and under it is an electric module of some kind. it has a disclaimer about not over-torquing its bolts. its apparently important since its between the fender and air box, away from heat... im sure i would have to put in a heat shield and keep the plastic cover,but WHAT is this electric box??? i cant find anything anywhere. pics of similar setups would be appreciated.
  2. #2 Re: Cold air/Short ram Intake
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    imagesCACY031H.jpgare you talking about the pcm that is inside of the air box? has 2 big connectors on it?
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Cold air/Short ram Intake
    Feb 2013
    Houston
    cant tell from that pic. i can only see the top it has heat reflective/ insulation surrounding it... wish i could post pics. if someone could find pics of the engine bay, its bout the same as the then generation LeSaber. 3800 series 2. i cant seem to find much on google either.
  4. #4 Re: Cold air/Short ram Intake
    Pennsylvania
    There shouldn't be anything in the engine bay that can't handle heat or water. My guess is it's the pcm anyways, which we all let dangle in the breeze.
  5. #5 Re: Cold air/Short ram Intake
    Sep 2011
    Copperas Cove, TEXAS
    Yup, my pcm just "Dangles" floating around giving no fvcks.
  6. #6 Re: Cold air/Short ram Intake
    Howell, NJ
    mine too
  1. Short Ram Intake
    By sirricealot in forum 5.3L V8 (LS4)
    Last Post: 12-06-2012, 11:49 AM
  2. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  3. DIY Short Ram Intake & ECU Placement
    By Elite6 in forum How To Write-Ups/Tech Tips
    Last Post: 09-16-2010, 11:05 AM
  4. Short ram intake. Done!
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 07-12-2010, 08:33 PM
  5. short ram intake
    By digilue in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-29-2008, 04:08 AM
