Thread: Engine surging and dieing
Results 1 to 13 of 13
  1. #1 Engine surging and dieing
    Apr 2009
    vegas
    99 grand prix gt. 3800, engine surges and tac pulsates +/- a couple hundred rpms. Some times it will do it while setting idle and sometimes it will surge while under acceleration. some times when stopped at a red light it will surge and die. It will restart and if you keep a little throttle it will stay running. If it sits for a while, it will start fine and run fine untill the next episode, which may be a while.
    I was having the crank position sensor symptoms, and have changed the sensor a few weeks ago for the second time in four years. after the sensor change it ran fine untill a couple days ago, when it started this problem. There are no check engine lights or stored codes. Any sugestions would be greatly appreciated.
  2. #2 Re: Engine surging and dieing
    Jul 2012
    Chicago
    It's weird that the tach is still doing that. Hmm. Test your ICM and coils. MAF too.
    -Carl
  3. #3 Re: Engine surging and dieing
    Minnesota
    Sounds like a crank position sensor again but thats really odd that it started back so soon. maybe ignition coils or vac leak?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  4. #4 Re: Engine surging and dieing
    Apr 2009
    vegas
    Ok so after not really trusting what my wife was explaining about the problem with the car, I drove the car for about 20 miles, with street driving and interstate driving and it ran fine, with no isues.
    A couple of days later we took the car out for dinner. Just driving down the street, a couple blocks, under normal accelleration, i could feel the car surging a little, and the tac bouncing a couple hundred rpm. Got on the interstate and accelerated to speed, about 65 mph cruising and when you accelerate a litle to around 2500 rpm the car would start surging and tac bouncing a couple hundred rpm. If you let off to under 2500 the ca would quit surging.
    After dinner, just driving down the street at about 35-40, the car just died, but fired right back up. There was no engine light displayed.
    Now my wife claims that even driving down the interstate, some times the car will just die, but will start right back up.
    Yesterday She was driving and it and it died while moving, and the check engine light finnaly came on. When I checked it there were 4 codes in the system, P0171, PO327, P0336 and P0716. Now I am not sure if the crank position sensor code was allready in there, becouse there were no engine light on, when i changed the cps and I did not check for stored codes. The CPS is only a couple of weeks old. and what the car is doing now is not the same as before the CPS change. Any Ideas?.....
  5. #5 Re: Engine surging and dieing
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    maybe a maf?? just a guess not sure what all the codes are. but my 2000 would run rough then die but yet start back up with no check engine light on.. ended up being the maf.... that surging can get dangerous i was at a stop light and it surged and i didnt have my foot on the brake that hard and i almost rear ended the car in front of me lol
    also would run fine somedays and run like s*** the next with the bad maf
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  6. #6 Re: Engine surging and dieing
    Apr 2009
    vegas
    Ok so I cleaned the MAF sensor with some electronic cleaner. It really dint look dirty, but did it any way. I checked for vac leaks and did not find any. Any other ideas?
  7. #7 Re: Engine surging and dieing
    Jul 2012
    Chicago
    Swap your ICM and coils with known good ones.
    -Carl
  8. #8 Re: Engine surging and dieing
    Apr 2009
    vegas
    Yea I dont have any known good extra ICM or coils. I would have to purchase new ones. I know that we are saying that a p0171 is a vac leak, but i have yet to find one, but I will keep looking.
    Any ideas about the other codes?
  9. #9 Re: Engine surging and dieing
    Apr 2012
    hampshire
    i had similar issues with my car surging and dying and it turned out to be there fuel pressure regulator.
  10. #10 Re: Engine surging and dieing
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    i was thinking fuel but i am more leaning towards the ign control module. i would def try to find a good used one to try as these can be expensive and based on a guess i wouldnt run out and buy new... cars sure can be stubborn. hope you figure it out.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  11. #11 Re: Engine surging and dieing
    Jan 2013
    United States
    not sure if this will help but my 2001 grand prix did this and it ended up being the spark plug wires. but mine was a little more excessive then just a few hundred rpms. so i switch out all my coil packs and all new plugs and all new wires and the problem was fixed. i would be accelerating and out of no where it would basically die out but never to the point of full stall. it would always stay running just acted stupid. they told me it was probably a short somewhere in the spark wires, cut wire or something but never found.
  12. #12 Re: Engine surging and dieing
    Florida
    find someone in your area with a scan tool or tuner and make sure your map is not showing a vac leak, your maf is correct and all before just throwing parts at it.
  13. #13 Re: Engine surging and dieing
    SE Level Member Paintball0027's Avatar
    Jul 2010
    Michigan
    I'm kind of having the same issues. I had these issues two years ago and ended up replacing the MAP, and it didn't help. Replaced the MAF and that was it. Ran fine for two years. Two weeks ago it randomly stalled while driving. I could keep it running by giving it gas. Unplugged the MAF to test it, stalled immedietly. So I think the MAF is fine. Changed the PCV valve kit and it ran fine for a week with no problems. Now it starts to studder randomly with the RPM's just bouncing around from 1k to 1500. Sometimes while driving and giving it gas the engine studders heavily. When I press the gas I can hear my cold air intake stop and the RPMs drop. Once I let off the gas I can hear the intake start back up and the car tries to run.
    2007 Pontiac Grand Prix GXP - ZZP exhaust,1999 Pontiac Grand Prix GT -Falken Cinturato 828 tires,GMPP performance handling kit,oversized front sway bar, front strut tower brace, tubular trailing arms, spectre cold air, 180* drilled thermostat, ZZP Racing transmission with 3.29 gears, 4th gear hardened shaft, shortened dog bones.
  1. Engine surging, hesitating (It's Fixed !!!)
    By BDEGhost in forum General Tech Discussion
    Last Post: 05-27-2010, 08:36 PM
  2. Help with SES codes, engine surging.
    By Fast68Camaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 06:20 AM
  3. Surging Through Low Speeds and No Check Engine Light
    By NapNinja317 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-15-2010, 11:06 AM
  4. need help with surging engine.
    By firefighter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2009, 10:51 PM
  5. 1999 SE 3100 Replaced engine, Surging at idle
    By socalchlln in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2009, 10:09 PM
