Thread: i need help! engine ticking?? 3800
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
  1. #1 i need help! engine ticking?? 3800
    SE Level Member a.caldwell11's Avatar
    Oct 2008
    tn
    i have a 97 grand prix gt with the v6 3800..... I was told when i bought it they thought the oil pump was out....... ive looked at it and im pretty sure the oil pump isnt out..... but there is a ticking type noise the sounds like its coming from the top of the engine...... i looked at the rocker arms and they all appear to be lubricated and in good shape..... i have no clue what this could be.... the noise speeds up when you give it gas...... but it has a steady pattern....... i thought maybe it was a spun bearing..... but with the oil pump working im hoping its not that..... i dont know much about engines so im getting into a whole new territory and im trying to go the cheapest route..... if its something major the guy i bought it from said hed give me my money back.... but i dont have a whole lot of time to let him know either way... any help would be appreciated!
  2. #2 Re: i need help! engine ticking?? 3800
    Barksdale AFB, LA
    Collapsed lifter?
    2009 Subaru Impreza WRX STI
  3. #3 Re: i need help! engine ticking?? 3800
    Oct 2008
    tn
    is there any way i can tell if thats what it is?
  4. #4 Re: i need help! engine ticking?? 3800
    Barksdale AFB, LA
    Not to my knowledge, without removing the lifters.
    Out of curiosity, where in TN are you?
  5. #5 Re: i need help! engine ticking?? 3800
    Oct 2008
    tn
    do you know if it could possibly be the fuel injectors???
  6. #6 Re: i need help! engine ticking?? 3800
    Oct 2008
    tn
    oh and im about 20 mins west of nashville
  7. #7 Re: i need help! engine ticking?? 3800
    PA
    Quote Originally Posted by a.caldwell11 View Post
    I know my fuel injectors do make noise. And overall, the entire valve train isn't quiet by any means. If you are getting oil up top and good oil pressure overall, I would run it.
    2001 GSE
  8. #8 Re: i need help! engine ticking?? 3800
    Barksdale AFB, LA
    Yeah, my injectors tick as all do. That's why GM made the engine cover as a sound shield to keep it down.
    Reason I asked where you were is I used to live in Memphis a couple years ago and still go back to visit.
  9. #9 Re: i need help! engine ticking?? 3800
    Oct 2008
    tn
    this definitely isnt a normal sound.....
  10. #10 Re: i need help! engine ticking?? 3800
    GT Level Member njbrain's Avatar
    Rhinelander WI
    What is your oil pressure?
  11. #11 Re: i need help! engine ticking?? 3800
    I live here. UR LOSN's Avatar
    Rockford, IL
    if you have a collapsed lifter...... the lifter would not like to pump up(or bleed off). this would create a gap in the lifter pushrod area, the pushrod would not go up fully to meet the rocker. this would cause one heck of a tick..... a fast tick, not low end knock.
    when driving it...do you feel the car miss? I would not drive the car very long...untill replaced.
    can you make a recording and load it up?
  12. #12 Re: i need help! engine ticking?? 3800
    Oct 2008
    tn
    yes there is a miss as well.... im not driving the car at all.... its sitting in my driveway bought it as a second car.... im thinking ill just have the guy giveme my money back.... ill see if i cant upload some sort of recording of it before i do that
  13. #13 Re: i need help! engine ticking?? 3800
    PA
    If there is a miss, fix that first. It is going to be hard to tell what is going on with the engine with it missing.
    Old rule of thumb. Fix what you know is wrong, then move on.
    2001 GSE
  14. #14 Re: i need help! engine ticking?? 3800
    Feb 2008
    How much did you buy the car for? Depending on whats wrong with it, it might still be worth keeping.
    I remember talking to you about this before you got it, and it's good to hear that I was right about the oil pump. That hopefully means that the engine has a better chance for getting more miles on it. My question is, when it misses it it just as consistent as the tick? Knowing the answer to that might lead you to where the miss might be coming from. So I agree with finding out what is making the engine miss.
    Here is how to find out which lifter it is if it is a lifter. Unfortunately this involves taking off the valve covers. Get a automotive stethoscope and put the end on the rocker stud, the one that has the collapsed/loose lifter with sound different than the others. When you find out which one it is loosen the nut completely and re-torque it to 18 ft. lbs. (15 NM), then by using a torque angle meter, rotate the an additional 90 degrees (Chilton manual).
    I suggest re-torquing because you don't know if someone was already in there and didn't do it correctly. If a lifter is truly collapsed this will not fix it, but at least you will know which one it is so you can just replace it.
  15. #15 Re: i need help! engine ticking?? 3800
    Feb 2008
    Hmmmm Ticking + misfire sounds like a lifter to me, too. Of course, you could have the same problem I just finished fixing on my '97 - spun cam bearing being beaten to death by one of the lifters!! I doubt that, though. You would probably have the oil pressure light in the dash coming on. See if you can hook up a gauge and check your pressure. You should have a nice, healthy 50+PSI (I only had 4 with my spun bearing).
    If the oil pressure checks out and the rockers are good, I'd say spend $100-200 and get new intake manifold and SC gaskets and lifters and spend an evening replacing them. There's a video in the How-To section on doing it.
  16. #16 Re: i need help! engine ticking?? 3800
    Barksdale AFB, LA
    I've seen collapsed lifters before on 3800s so that's why I mentioned it. Usually owners complain of abnormal loud ticking. I've mostly seen it here lately on 2000-2002 models. Stock motors, as well.
  17. #17 Re: i need help! engine ticking?? 3800
    Feb 2008
    Quote Originally Posted by DanGTP View Post
    Unless the bulb burned out!!
  18. #18 Re: i need help! engine ticking?? 3800
    Oct 2008
    tn
    good news i only gave him 500 for it.... well i think thats good news lol.... its been rainy here for the past few days is why i havent gotten a recording of the car up.... ill get that sunday..... ill see what i can do about checking out everything else... i appreciate everyones input... ive already gotten the valve covers off.... so thats good.... those were some what of a pain.... anyhow... ill get that video up tomorrow... and like i said.. thanks to everyone ill let you know how it goes
  19. #19 Re: i need help! engine ticking?? 3800
    Oct 2008
    tn
    here is the sound clip... motor knock - Putfile.com
    also i took the motor cover off.... and i can feel it knocking in that plastic cover on top of the engine... im assuming it probably is a lifter..... let me know what you think
  20. #20 Re: i need help! engine ticking?? 3800
    Barksdale AFB, LA
    Lifter.
  1. SLP header flex section ticking
    By copterdoctor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2008, 10:29 AM
  2. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
  3. weird ticking noise coming from turbo
    By lilredss0287 in forum Turbo
    Last Post: 09-05-2008, 08:56 PM
  4. My "second" GP and third 3800 engine!
    By Deezul_AwT in forum Introductions/Noob Questions
    Last Post: 02-23-2008, 01:04 PM
