Thread: fuel tank removal
Results 1 to 14 of 14
  1. #1 fuel tank removal
    Bellevue, Neb. Close to Omaha
    I have a 2004 Grand Prix with a erratic fuel gauge. I understand the sending unit for the gauge can be repaired upon the removal of the fuel pump.
    I know the 2003 and older models have a fuel pump access panel in the truck, so I missed out on convenience by one year.
    So what kind of hoops does one have to jump through to remove the fuel tank from a 2004-2008 Grand Prix?
  2. #2 Re: fuel tank removal
    I thought the 04's and some 05's still had that.
  3. #3 Re: fuel tank removal
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    might wanna double check if you have the access panel in the trunk bc i have a 2004 and it has the access panel.
  4. #4 Re: fuel tank removal
    Correct. Check your trunk bro you have the access panel in your 04.
    04 Comp G.
  5. #5 Re: fuel tank removal
    That would be great if that were the case. I'll have to look in the trunk for the panel.
    Has anybody repaired the gauge sender? I see there's a repair kit on Rock Auto for around $20.
  6. #6 Re: fuel tank removal
    Lots of people have. I personally haven't but the wife's bonneville needs it done whenever I get around to it.
  7. #7 Re: fuel tank removal
    SE Level Member GrandPrixGt2001's Avatar
    Aug 2012
    Rochester
    I have a 2001 Pontiac grand Prix gt with the same erratic fuel gauge although neither my husband or i can seem to find the access panel in the trunk.. does anyone have am idea or a photo as to where this is??
    ~Ali~
  8. #8 Re: fuel tank removal
    Look under the carpet it's a piece of metal with like 8 nuts holding it down. It's at the front of the trunk in front of the spare tire. You can't really miss it.
  9. #9 Re: fuel tank removal
    Mar 2013
    kansas
    my 07 does not have this panel would this mean id have to drop my whole tank?
  10. #10 Re: fuel tank removal
    Yep
  11. #11 Re: fuel tank removal
    Or if you want to get all crafty, cut a hole where the pump is and get it out like the older cars.
    Just make a new cover the hole and paint so it can't rust. It would be way quicker and less of a pain to do it this way.
  12. #12 Re: fuel tank removal
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    I'd be afraid to cut that close to the tank. Back it up on some ramps and get it done...
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  13. #13 Re: fuel tank removal
    Well I wouldnt use a cut off blade, just some metal shears, it can be done.
  14. #14 Re: fuel tank removal
    Mar 2013
    kansas
    anybody got a diy for removing the tank. this fuel issue is getting to be a problem im gunna drop the tank i suppose
  1. Fuel Tank
    By JabezAbreu in forum Introductions/Noob Questions
    Last Post: 02-12-2013, 04:39 PM
  2. fuel tank
    By 99grandgt in forum General Grand Prix Discussion
    Last Post: 07-27-2012, 07:44 PM
  3. Fuel tank is 12-13 gallons?
    By Xanthous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2011, 11:41 AM
  4. Gas tank removal
    By daveg in forum General Tech Discussion
    Last Post: 09-09-2009, 05:17 PM
  5. fuel tank capicity
    By whiteknuckle in forum General Tech Discussion
    Last Post: 01-19-2009, 07:44 PM
