Thread: WOT misfire at 2-3 shift
Results 1 to 7 of 7
  1. #1 WOT misfire at 2-3 shift
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Hi today i got a po300 misfire while going WOT from 2-3 shift. So far its only done it on a 2-3 wot shift. Also still have p0171 that i cant figure out. Im wondering if it could be my battery because ive had to jump my car a few times to start it in the morning.
  2. #2 Re: WOT misfire at 2-3 shift
    You have a vacuum leak or a dirty MAF.
  3. #3 Re: WOT misfire at 2-3 shift
    Dec 2011
    Decatur
    I'll have to try and look again. I sprayed carb cleaner but didn't find anything.
  4. #4 Re: WOT misfire at 2-3 shift
    One of the things I've found that can cause a P0171 is low system voltage. Corroded battery cables, maybe a bad battery, poor connections that provide resistance etc.
    Vacuum leaks are also common.
  5. #5 Re: WOT misfire at 2-3 shift
    Dec 2011
    Decatur
    Well I know my battery is bad cause sometimes the car won't start and when it does its a very weak crank.
  6. #6 Re: WOT misfire at 2-3 shift
    Dec 2011
    Decatur
    Alright so I tried spraying didn't notice any idle jump. My gauge says I'm going from around 600 something to 700. It jumps to quick to get an exact number.
  7. #7 Re: WOT misfire at 2-3 shift
    Dec 2011
    Decatur
    Alright guys its gotten a lot worse. Now the idle is supper jumpy and sometimes it will die completely and take a few secs to start uo again. I check for vac leak but didn't find one.
  1. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  2. 97 gtp misfire/shift issue
    By Wilong in forum General Tech Discussion
    Last Post: 05-08-2012, 07:04 AM
  3. Misfire?
    By blackflag in forum General Tech Discussion
    Last Post: 03-14-2012, 09:41 AM
  4. Misfire?
    By Sabzz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2010, 10:52 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
