Thread: Small coolant leak. Radiator drain plug
Results 1 to 4 of 4
  1. #1 Small coolant leak. Radiator drain plug
    May 2012
    West Haven
    2001 grand prix
    I have a slow leak on my driver side right underneath the radiator at the drain plug. There is no easy way to get to it from underneath. The car is too low and there is a plastic shield blocking me. The plug on this car in the white plastic "butterly" knob that is perpendicular to the drain itself.
    I cannot post a picture. Keeps saying I am exceeding my quota even if I shrink it.
    Is it as simple as replacing the knob, could the drain be faulty, any other underlying problems could cause this? Is there a way to replace it without flushing the whole system? What would you recommend.
  2. #2 Re: Small coolant leak. Radiator drain plug
    St. Louis
    You could always try tightening the plug. May just have worked it self a bit loose.
  3. #3 Re: Small coolant leak. Radiator drain plug
    May 2012
    West Haven
    I tried moving it from up top but it wasn't budging plus its like 10 degrees outside. I can always wait for warmer weather, its not leaking that severe. Is there a good how-to for replacing the plug/bolt? I did a quick search and I guess you can remove the plastic cover underneath the car.
  4. #4 Re: Small coolant leak. Radiator drain plug
    St. Louis
    You are correct. You remove the lower air dam (that big plastic thing) and can get to it from there. Just throw some jackstands under it and go to town.
    As far as replacing the plug, I'm not sure since IIRC it's all plastic. The one on my old rad has an O-ring that goes on it. Maybe yours has shrank and is leaking. Keep in mind this is on a non-OEM rad, but I would think they all have it.
  1. Flush/Drain Coolant from Bottom Radiator Hose
    By kennn in forum General Tech Discussion
    Last Post: 07-08-2012, 03:56 PM
  2. Radiator drain plug
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:40 PM
  3. Where is the drain plug located on my radiator
    By ls6velless454 in forum General Tech Discussion
    Last Post: 09-06-2010, 04:16 PM
  4. drain plug oil leak
    By 05grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2010, 02:34 PM
  5. Special tool needed for radiator drain plug on 2000 GP?
    By halfwit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2009, 09:31 PM
