Thread: Oil leak
Results 1 to 12 of 12
  1. #1 Oil leak
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    So I have oil leak that I can't figure out exactly where it's coming from. It doesn't look like it's coming from the valve cover but i didn't notice it until after i put on my rockers. Maybe someone can help narrow it down. I'm wondering if its a head gasket because I don't know where else it would be coming from. It i can see the oil on the block down by the crossover on front of the engine. It's an 07 L26 with a turbo. Sorry for the bad pictures.
  2. #2 Re: Oil leak
    read this thread, id give you the same advice to find where the leak is coming from.
    http://www.grandprixforums.net/found...ing-74471.html
  3. #3 Re: Oil leak
    May 2012
    Fort Campbell, ky
    I read that post and it doesn't seem to help. I know it's not the oil pan. I know for sure its not the oil level sensor. Because of where the I can see the oil building up I highly doubt it's the valve cover. I have cleaned it and watched but it is a very slow leak. I just don't know where else it would come from but the head gasket because if where the oil is at.
  4. #4 Re: Oil leak
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    lim end cap?
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  5. #5 Re: Oil leak
    If you hop under and look up, here's how you diagnose oil leaks.
    If the oil isn't much above the pan on teh block, it's the pan or rear engine cover. If it's higher, it's the VC's 3800's are easy.
    It's even easier when you say you tossed rockers in and then it started. Which leads me to think you didn't do gaskets/grommets when you did the rockers.
  6. #6 Re: Oil leak
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    i am with Erik lim valley gaskets
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  7. #7 Re: Oil leak
    May 2012
    Fort Campbell, ky
    I did replace the gasket and grommets when I did the rockers. I was think it was the LIM but wasn't sure. Due to the location I figured it had to be the LIM or a head gasket. Thanks
  8. #8 Re: Oil leak
    i made my v/c bolts to tight and they leaked from day one, worse then before i changed them. (new gaskets and grommets)
    so i took the one that was leaking back off, cleaned it all up nice, then put the gasket back in the cover, and smeared the thinnest smear of rtv on the gasket only, then put it back, and only snugged the bolts down good., no more leak for me.
  9. #9 Re: Oil leak
    It's tough to overtighten them with that stopping sleeve on them.
    I'd think it was LIM before HG. Give it a cleaning and you'll know for sure.
  10. #10 Re: Oil leak
    Apr 2009
    any way it could be coming from the oil supply line for the turbo? i dont see the line in the pics but maybe under boost it squirts...just throwing it out.
  11. #11 Re: Oil leak
    May 2012
    Fort Campbell, ky
    Quote Originally Posted by mikedinthecity View Post
    I checked that because I have had that problem before and it's good. I think it's got to be the lim. I'm going to remove some stuff this weekend to see if I can narrow it down more
  12. #12 Re: Oil leak
    Or you could clean it down and watch for where it begins seeping from.
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  5. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
