Thread: p0300
Results 1 to 7 of 7
  1. #1 p0300
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    I just recently top swapped my grand prix gt and all was good for a day. i had a rocker pop off so i had a cylinder 6 misfire. Fixed that now i have a random one. i no its cylinders 2 and 3 cause i had a friend at gm use a scanner that showed which cylinders were missing. I have brand new autolight 104s gapped .55. New wires, coils and i have tried different icms. I have also tried moving fuel injectors around but it doesnt seem to be working because when i pull the injectors of the cylinders the idle doesn't change. But when i swapped them then pulled the suspected injectors off the idle dropped and got ruff so i wouldn't think they are bad. Compression check was good. Fuel pressure was good. Anyone else had this problem and found out why. Could it be my ZZP pcm tune.
  2. #2 Re: p0300
    any other mods?
    is it knocking?
    If you're unplugging/swapping the injector and nothing is changing then I'd try a new plug or check the wiring on the injectors that aren't firing.
  3. #3 Re: p0300
    Dec 2011
    Decatur
    Headers, 1.9s rockers, 180 therm. I tried swapping plugs. I tested the wires with a noid light and they were getting power.
  4. #4 Re: p0300
    Dec 2011
    Decatur
    How do I test vacuum. And injector pulse rate?
  5. #5 Re: p0300
    Dec 2011
    Decatur
    Anyone?
  6. #6 Re: p0300
    Dec 2011
    Decatur
  7. #7 Re: p0300
    Dec 2011
    Decatur
    Well I figured it out. I put the old plugs in and it runs better but sputters if giving to much gas. I had autolite 104 gapped at 56. My old plugs that are in now are gapped 50. I was just wondering am I running to rich and fouling plugs or did I just have them gapped to much.
  1. p0300 missfire
    By falcz420 in forum Engine
    Last Post: 02-11-2012, 02:13 PM
  2. 98 gtp missing...p0300
    By cp93 in forum General Tech Discussion
    Last Post: 02-03-2012, 06:32 AM
  3. p0300 miss
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2012, 04:30 PM
  4. My P0300 discovery
    By mayoke in forum General Tech Discussion
    Last Post: 09-01-2011, 08:12 AM
  5. p0300
    By fratzke7 in forum General Tech Discussion
    Last Post: 10-10-2008, 09:19 AM
